Am I right thinking this little anvil (if it is an anvil) is for jewellery-making, clock-making or similar?
All faces except the semi-circular groove that surrounds it, are ground.
The higher bick is ground flat continuing the flat top, and has an 1/8" hole drilled vertically though it.
The base is drilled up into the body, and tapped 5/16" X 18tpi; presumably to allow fitting it to a suitable stand, vice-block or bench. I can't identify if BSW or UNC (same pitch), testing by screws.
Apart from the thread, measuring it to ascertain if of inch or metric sizes, is inconclusive
It holds no maker's names or marks.
Overall length X height, about 4.5 X 1.5" .
I forget when and where I came by it, probably in a collection of old tools I'd bought somewhere, or been given lest they be useful.
