Soldering cast iron
Soldering cast iron
Home › Forums › General Questions › Soldering cast iron
Viewing 25 posts - 1 through 25 (of 32 total)
  • #625655
    David Noble
      @davidnoble71990
      Any tips on how to soft solder cast iron please? I'm struggling to get it to 'wet'
      David
      #28967
      David Noble
        @davidnoble71990
        #625656
        Brian Wood
          @brianwood45127
          Hello David,
          I'm not surprised! The carbon content will make it impossible as it tends to act as a surface contaminant.
          Much better success is assured in joining to Cast Iron with high temperature bronze welding which also makes a strong joint. You do need oxy/acetylene to get the temperature needed though
          Regards Brian
          #625657
            Preheating to red heat will drive the carbon to the surface which can then be wire brushed off when the part has cooled, you can then silver solder and I believe the same method can be used for soft soldering though I have only used this method for silver soldering..
            #625660
            David Noble
              @davidnoble71990
              Thanks, I haven't got enough heat to silver solder or to get it to red heat. I'll have to think again.
              I started by going to a local engineering shop to ask them to braze it. They said that they don't use acetylene any more for various reasons i.e. cost and availability and the gas they use isn't suitable for brazing. The second and third shops that I tried gave me the same answer. The fourth told me 'yes no problem' but after three weeks I've just been to collect it as they still haven't done it.
              David
              Edited By David Noble on 21/12/2022 16:13:18
              #625665
              RMA
                @rma
                Depending on application and whether you consider soldering essential. I have used JB weld on CI and it works a treat. Much prefer the original to the fast stuff.
                #625681
                Brian Wood
                  @brianwood45127
                  Hello again David,
                  I have the necessary gases and will do the brazing for you but a bit of information beforehand would be helpful in planning the work if it is a big job.
                  Send me an email please wood_y(at) btinternet(dot)com There is an underscore between the d and the y
                  Regards Brian
                  #625685
                  Ady1
                    @ady1
                    Decent cast iron welds pretty easily if you've got a pal with a buzzbox
                    #625699
                    David Noble
                      @davidnoble71990
                      Thank you Brian, that's very kind.
                      David
                      #625718
                      Jeff Dayman
                        @jeffdayman43397
                        Hi David, no idea what needs to be repaired, but if it is a simplish sort of part, is fabbing/machining a new one from solid CI stock like Durabar or Meehanite a possibility? Obviously this won't be an option if it's something big or complex but worth a thought of it's smaller and not too involved. Just a thought.
                        #625723
                        David Noble
                          @davidnoble71990
                          Posted by Jeff Dayman on 21/12/2022 22:18:09:
                          Thanks Jeff, yes it would be possible but a repair will be easier and more cost effective/cheaper
                          David
                          #625724
                          Pete.
                            @pete-2
                            What are you trying to repair? can we see? I'm curious to know what a professional outfit put off for 3 weeks.
                            #625740
                            David George 1
                              @davidgeorge1
                              Hi David I was given a cast iron base casting for a Stuart steem engine. If had been cast faulty with a piece of the base not filled. I cleaned up the area and made an insert of cast iron to match with a little to clean up after soldering. Fluxed and heated in a hearth to keep in the heat in with my blow torch and silver solder no problem.
                              David
                              #625753
                              David Noble
                                @davidnoble71990
                                Posted by Pete. on 21/12/2022 22:48:10:
                                Hello Pete, of course you can see, it's just that I'm a little embarrassed having admitted that I'm trying to soft solder it!
                                It's a steel gear wheel and a cast iron sleeve on a Mellor lathe that I'm restoring.
                                David
                                #625757
                                Ady1
                                  @ady1
                                  Could you key it on? Better for high torque applications
                                  #625759
                                  duncan webster 1
                                    @duncanwebster1
                                    High strength loctite?
                                    #625770
                                    David Noble
                                      @davidnoble71990
                                      I hadn't thought about a key, thank you.
                                      The problem is a little more complex though. Having got the lathe as a box of bits, I 'think' that originally the gear wheel was also cast iron and part of the sleeve. for some reason the wheel has broken and this is an attempt by someone to repair it. The wheel is only bored out for 3 or 4 mm just enough for a register. If I machine the wheel all the way through to accept a key, I think that it will leave the sleeve too short. There is a triple pulley to fit on the other end of the sleeve.
                                      Last resort I think will be to make a new sleeve and wheel in one piece.
                                      David
                                      #625772
                                      noel shelley
                                        @noelshelley55608
                                        Hi David, not sure where you are but I'm on the N Norfolk coast = Hunstanton. If Brian is a long way from you and I'm nearer then I also have oxy propane Etc and will happily do it for you. Even a while you wait ! PM me if I can help. Noel.
                                        #625773
                                        Ady1
                                          @ady1
                                          Four quick tackwelds with a decent buzzbox would do it in 5 minutes
                                          100-120 amps with mig gasless wire
                                          Instant practical problem fix… but cosmetically ugly
                                          I had to use a key because my replacement cog was aluminium
                                          Edited By Ady1 on 22/12/2022 11:28:48
                                          #625783
                                          David Noble
                                            @davidnoble71990
                                            Posted by noel shelley on 22/12/2022 11:12:44:
                                            Thanks Noel, Brian is definitely nearer.
                                            David
                                            #625817
                                            David Noble
                                              @davidnoble71990
                                              O.K. After chatting with Brian, I've decided not to prevaricate any longer and I've ordered a piece of cast iron to make a new one in one piece.
                                              Thanks all, David
                                              #625955
                                              Grizzly bear
                                                @grizzlybear
                                                David N,
                                                An update would be very much appreciated.
                                                Good luck, Bear……
                                                #625970
                                                David Noble
                                                  @davidnoble71990
                                                  Hello Bear, after chatting with Brian, I've decided to make a new one. I've ordered a piece of cast iron and when it arrives, I'll make a new gear wheel combined with the sleeve. I'll try and post again when I have something to show you but it will be a week or two!
                                                  David
                                                  #625995
                                                  Brian Wood
                                                    @brianwood45127
                                                    Hello again David,
                                                    I did suggest you graft the gear you already have onto the new piece of cast iron bar and how to secure it. There seems to be nothing wrong with the gear itself, it will save you time as well.
                                                    It is of course your choice but as you describe your plan it involves making the gear as well. Either way, I hope it goes well for you.
                                                    Regards Brian
                                                    #626000
                                                    David Noble
                                                      @davidnoble71990
                                                      Morning Brian,
                                                      Yes, you did but I thought 'it would be an interesting job' famous last words! and I suppose if it all goes terribly wrong I can still graft the gear on as you suggest.
                                                      Best Wishes, David
