Thumb screw material
Home › Forums › General Questions › Thumb screw material
  • #570450
    Dalboy
      @dalboy
      I am repairing my Scribe block and have made the tilting lever as I have shown in another post.
      I have looked in some of my books but can not find what steel would be suitable to make the thumb screw from it will have a 4mm thread on it can anyone suggest what to use and could someone suggest any books which will give an idea of materials for certain applications
      #28429
      Dalboy
        @dalboy
        #570453
        Jon Lawes
          @jonlawes51698
          Will normal mild steel not cut the mustard? Nice and easy to thread and takes a nice knurl if required.
          #570458
            A free cutting mild steel like EN1A or 230M07 in new money will turn thread an knurl easily
            #570466
            Nick Wheeler
              @nickwheeler
              Brass is perfectly adequate for a thumbscrew. Looks good too if that matters to you.
              #570472
              Tony Pratt 1
                @tonypratt1
                Mild steel
                Tony
                #570477
                Vic
                  @vic
                  Either of those suggested would be fine but Brass might look nicer?
                  #570490
                  Dalboy
                    @dalboy
                    Thank you all I have tried hot rolled steel but at the slightest knock it just wants to bend. I have thought about brass as suggested it would look good and contrast with the steel. I did think of using some stainless steel which I have but until I try it will not know how well it machines.
                    I could use the existing thumb screw top and insert a 4mm threaded part of a bolt into it but would like to make it in one piece if for no other reason than to practice my machining.
                    #570492
                    duncan webster 1
                      @duncanwebster1
                      ot sure what you are describing as thumb screw, but if it's knurled I'd leave stainless alone. If it's what I'm imagining, a screw with a big knurled head, what I'd do is loctite a bit of capscrew into a knurled and tapped bit of MS or brass
                      #570503
                      ega
                        @ega
                        Posted by duncan webster on 08/11/2021 21:33:39:
                        Or drill an under-sized hole and press fit.
                        #570504
                        Nick Wheeler
                          @nickwheeler
                          Posted by Derek Lane on 08/11/2021 21:13:43:
                          I would only ever make knobs, thumbscrews etc by inserting a separate male thread into them. That's because it's quicker, easier, stronger and less wasteful of material.
                          Make one that way, and another in one piece and you'll see what I mean.
                          A length of decent quality studding in suitable sizes – M5/6/8 for me – should be in everybody's material stash.
                          #570515
                          Bo’sun
                            @bosun58570
                            As long as Loctite (or similar) is strong enough, I like the idea of a separate threaded portion to save material, and for a nice looking piece, I'd use steel studding and a brass knob.
                            #570521
                              Please permit a slight digression, Derek
                              Having some background in Ergonomics, and being a frequent user of Microscopes [which tend to feature lots of twiddly screws!] … I would highly recommend using a straight knurl in preference to a diamond pattern.
                              Bob Unitt 1
                                @bobunitt1
                                What a very medieval thread-title…
                                #570530
                                  The problem that I had with thumbscrews was breaking the "knob" portion from the thread when knurling.
                                  My solution is to knurl the section closer to the chuck, and then turn down the outer portion to size ready to cut the thread.
                                  In this way the knurled "knob" can be quite big in comparison to the thread diameter. (Say 12mm bar knurled, but with a M4 thread. ).
                                  #570534
                                  John Haine
                                    @johnhaine32865
                                    A quick Google shows that ready-knurled stock can be bought.
                                    #570537
                                    noel shelley
                                      @noelshelley55608
                                      A 12.9 grade socket cap head with a press fit knurled head would look the part, I think ! Noel.
                                      #570544
                                      Nick Wheeler
                                        @nickwheeler
                                        Posted by noel shelley on 09/11/2021 10:14:22:
                                        That's all the lock for my top slide is: the original screw with an aluminium head pressed over it. Well, hammered over it, as I didn't bother to remove the screw. I modified the carriage lock screw while I was at it. Now I can lock the slides without using a tool, which is how it should have been supplied.
                                        #570548
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi Derek, I made these adjusting screws in two parts, which saved on machining and material, both parts were made from used parts, which was a couple of old hand nuts and a couple of spindles from worn out gate valves which were Loctited into the nuts.
                                          These are used on my basic magnetic compass Compass which is virtually all made from used materials.
                                          Regards Nick.
                                          P.S. I hasten to say these are a lot larger than you need, but the principle is the same.
                                          Edited By Nicholas Farr on 09/11/2021 10:56:25
                                          #570549
                                          ega
                                            @ega
                                            Posted by Michael Gilligan on 09/11/2021 09:16:01:
                                            I agree and prefer to reserve the diamond knurl for items which are going to be pushed or pulled. I do find straight knurling more predictable, however, and it does rather depend what knurls are already installed!
                                            #570552
                                            ega
                                              @ega
                                              Posted by Nicholas Wheeler 1 on 09/11/2021 10:37:26:
                                              GHT discussed your last point in his Manual, pointing out that the various improvements to his top slide could have been incorporated at the factory but probably at uneconomic cost.
                                              #570594
                                              Dalboy
                                                @dalboy
                                                OK I went for a two part construction I found a new bolt with the 4mm thread which was too long and I found a piece of brass rod about 2" long. I also had a single sided knurling tool which I only brought to add texture to some of my woodturning (I need to buy/make a better one).
                                                Picture of the old and new screw
                                                #570597
                                                  yes
                                                  Jon Lawes
                                                    @jonlawes51698
                                                    I like the idea of the two part construction; I also can't abide material waste. The finished part looks very nice.
                                                    #570613
                                                    Dalboy
                                                      @dalboy
                                                      All complete and back in commission
