Keyway steel
Keyway steel
Home Forums General Questions Keyway steel
  • #405555
    Garry Coles
      @garrycoles69390
      Hi, I'm trying find a supplier of key steel 3/16 rectangular and 5/32 square. Can anyone help please.
      Garry
      #26564
      Garry Coles
        @garrycoles69390
        #405556
          What is the other rectangular dimension? I get 1/4 x 3/16 from MSC Direct
          You will probably have to skim down 4mm square for the 5/32"
          #405558
          John Haine
            @johnhaine32865
            If you're going to skim it down anyway, just start with ordinary steel bar? Apart from the dimension I don't thing there's anything special about the steel.
            #405562
            I.M. OUTAHERE
              @i-m-outahere
              I get mine from my local bearing supplier .
              Edited By XD 351 on 18/04/2019 09:44:19
              #405563
              Garry Coles
                @garrycoles69390
                I thought key steel was harder than ordinary steel. Otherwise I can make all my keys from my own stock.
                #405564
                  It's about the same as EN3 so nothing special.
                  I quite often use gauge plate as the width is always a good fit and as most of my keys are Gib Head anyway I need more in the other direction.
                  #405566
                  Anonymous
                    Posted by JasonB on 18/04/2019 09:49:12:
                    Depends where you get it from. Keysteel from industrial suppliers is normally EN8, an unalloyed medium (~0.4%) carbon steel.
                    Keysteel is also supplied slightly over nominal size so it can be filed to be a snug fit in the keyway. I use keysteel on my machine tools and traction engines for simple keys. For gib head keys I use gauge plate, like Jason.
                    #405570
                    I.M. OUTAHERE
                      @i-m-outahere
                      Posted by Andrew Johnston on 18/04/2019 10:08:48:
                      And here i was thinking there was something wrong with my keyway broaches 😁
                      #405583
                      Garry Coles
                        @garrycoles69390
                        Thanks all, I think I will use ordinary steel.
                        #405597
                        HOWARDT
                          @howardt
                          According to Macreadys orange book, EN6A – 080M30, is key steel. It is as supplied finished to British Standard, both imperial and metric key tolerances. Key steel can be bought in 12 inch lengths as a minimum, I think we always bought 36 inch, from most bearing suppliers. But do as most people do and use what is to hand.
                          #405656
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, commercial key steel comes in various grades of steel, but as Andrew says, commonly it is EN8 but you can get alloyed steel as well. It depends on the usage and the loads that are going to be applied to it, as to the choice of the material because keys can also be made from S/S, Brass, Aluminium, plastic or anything else that may be relevant.
                            A lot of people regard keys to be a passive component, but they do transmit quit heavy loads, so the material used should suite what is being applied to it. In most cases EN8 should be about the toughest Model Engineers would need. Toughness is more important than hardness as that will resist deformation better. In industry I've seen keys that have been sheared in half and even the top half deformed over the bottom half making it look like a stepped key.
                            Regards Nick.
