A Clash of Rivets
A Clash of Rivets
Home › Forums › General Questions › A Clash of Rivets
  • #399954
    Brian H
      @brianh50089
      Came across a problem that I hadn't considered whilst making the boiler for my Burrell-Boydell engine.
      I have drilled all the stay holes and the plan was to use 1/8" snap head rivets from the inside of the firebox.
      I've made 114 rings of 1/16" silver solder, threaded them onto the rivets and inserted the rivets from inside as planned.
      The problems cam in the corners where I could fit the rivets in the sides but I couldn't place rivets front and back in the corners because the side rivets were sticking up by the thickness of the silver solder!
      I took a chance on silver soldering by using propane inside the firebox instead of oxy-acet at the clubhouse and it worked, I can now install the missing rivets and heat it all up again.
      Some you win!
      Brian
      #26481
      Brian H
        @brianh50089
        #399974
        Speedy Builder5
          @speedybuilder5
          If the Oxy-acet is available, I would preheat the firebox with propane, but not up to the point of melting the existing rivet joints, then swap over to Oxy-acet. If possible, use a lower temp silver solder as you don't really want to keep melting existing joints.
          BobH
          #399984
          Brian H
            @brianh50089
            Remaining rivets now inserted and silver soldered. I now need to clean it all so that another 114 rings can be place on the outside surfaces and melted in, but that will be MUCH easier. I'm expecting a few leaks that will require remedial work but hopefully the main heating work will be done.
            Brian
            (PS, I'll put up some pictures whan It looks respectable)
