Gearing
Gearing
Home › Forums › General Questions › Gearing
  • #381519
    kevin large
      @kevinlarge76611
      I am trying to slow an electric motor by gearing I have an 18 tooth driving off the motor I have a 45 tooth and a 24 tooth what needs to drive what
      #26300
      kevin large
        @kevinlarge76611
        #381521
        John Rudd
          @johnrudd16576
          Going from lo to high will give a slower final speed….Assuming you want the output shaft to turn in the sane direction as the motor, then, 18 on the motor driving 24 as an idler then 45 on the output…
          #381523
            Forget the 24T unless you can fit that to the motor and have either drive the 45T.
            With just 3 gears one will always be an idler and not do anything
            #381570
            larry phelan 1
              @larryphelan1
              Gears !!! such a wonderful subject !
              #381575
              HOWARDT
                @howardt
                A simple idler merely reverses direction so driver and driven rotate in same direction.
