What an earth are they called……
Home › Forums › General Questions › What an earth are they called……
  • #378638
    Matt Harrington
      @mattharrington87221
      I need to rebuild part of a mchine that has some telescopic driveshafts (about 18mm in dia)
      Each end is fitted to a uk and is locked in place with a c shaped spring (10mm width) to which is fitted a cross pin. So in cross section the clip looks like a circular letter E.
      I don't have the originals and I'm trying to source something similar – any idea what they are called?
      Matt
      #26275
      Matt Harrington
        #378640
        Brian Wood
          @brianwood45127
          Matt,
          Look for either C clips or E clips, you will recognise the ones that look right
          Brian
          #378641
          wheeltapper
            @wheeltapper
            not surprisingly they are called E clips.
            look on E bay.
            Roy.
            #378642
            David Standing 1
              @davidstanding1
              Do you mean lynch (or linch) pins?
              #378643
              Matt Harrington
                I have searched for ages and C Clips or E clips are not what I am after.
                Linch pin is along the principle but the spring is fixed to the end of the pin. I might need to do a sketch!!
                Matt
                #378644
                John Haine
                  @johnhaine32865
                  What's "a uk"
                  #378645
                  ASF
                    @asf
                    Is this the type of clip? Used on scaffold towers
                    #378646
                    Tony Pratt 1
                      @tonypratt1
                      Posted by John Haine on 01/11/2018 11:31:14:
                      What's "a uk"
                      At a guess it's a Universal joint.wink
                      Tony
                      #378647
                      Matt Harrington
                        John – sorry, yes UJ
                        ASF – that's the fella but I need them to be about 18mm internal dia? Any idea what they are called?
                        Matt
                        Edited By Matt Harrington on 01/11/2018 11:47:45
                        #378650
                        wheeltapper
                          @wheeltapper
                          if you right click on the above picture and choose "search google for image" there are loads of them.
                          Roy.
                          #378651
                          ASF
                            @asf
                            try searching scaffolding interlock clip
                            #378662
                            Matt Harrington
                              Posted by wheeltapper on 01/11/2018 11:50:54:
                              Roy.
                              Roy, All I get is Boss scaffolding and these are waaaay too big for me. The type is what I am after but I am struggling (no matter what I search for) to find smaller versions. Hence my quest to find out what they are called.
                              Matt
                              Edited By Matt Harrington on 01/11/2018 12:51:46
                              #378675
                                Try sprong loaded retaining pin, these may do the job:
                                #378677
                                  Or shaft locking pin…
                                  #378681
                                  Matt Harrington
                                    Neil, I have seen these ones. I'm not sure I have the space for the bit that sticks out. In addition, these see mto start at around 28mm dia which is too large for my application.
                                    Matt
                                    #378684
                                    Robbo
                                      @robbo
                                      This type of spring clip and pin is widely used in the disability aid market, for securing adjustable legs on stools etc.by the pin going through corresponding holes in an internal and external tube
                                      They usually consist of a plastic horseshoe with a steel pin. In this context they are known as a "push-on pin clip"
                                      #378685
                                      Mick B1
                                        @mickb1
                                        Try here:-
                                        Ah, no – didn't see any in 10mm. spring diameter. My missus has a Soari loom with adjustable-height legs that use these, but they're about 25mm/1in diameter.
                                        Edited By Mick B1 on 01/11/2018 14:39:29
                                        #378703
                                        JohnF
                                          @johnf59703
                                          Not quite what you describe but a similar device look on this link for "spring pins" **LINK**
                                          I searched for "spring clip clevis pin" and came upon this site, hope it helps [didn't look at sizes ]
                                          Matt Harrington
                                            Thanks John – These are going to work one end but not the other as the clip had to sit on the end of the universal joint and not obstruct the sliding part.
                                            At this rate I will end up making some from clock spring steel and riveting a pin in.
                                            Search goes on….
                                            Matt
