Brass insert
Brass insert
Home › Forums › General Questions › Brass insert
  • #356792
    Vic
      @vic
      I have a need for a single M6 locking screw with a brass insert to stop it marring a shaft. I’d like to modify a SS cap head socket screw to match the existing ones on the job. Anyone done this? Thinking how best to get the brass insert concentric as from experience the heads often aren’t concentric with the thread.
      #26015
      Vic
        @vic
        #356796
        Nick Hulme
          @nickhulme30114
          Drill and tap a small length of bar in the lathe, mark chuck jaw to work alignment if not using a collet chuck.
          Counter-bore the back to allow the screw to fit with the tip level with or proud of the front surface.
          Flip around again and machine to accept your insert.
          #356797
          bricky
            @bricky
            I read in MEW sometime back on the tips page of using a screw out of an electrical 13 amp plug,drill and tap the end of the bolt and locktite the screw in place.If the smalll screws aren't big enough there are plenty of larger brass screws that would fit the bill.
            Frank
            #356799
            bricky
              @bricky
              Frank
              #356801
              Jon
                @jon
                Done it a few times Vic for one offs and small quantity, same with grub screws.
                Turn something larger dia than head drill and tap it M6 your case.
                Screw Cap Head from inside out, may have to remove, might go back in central ish.
                Just drill in to the screw undersize to a depth then back in again with size required.
                Turn delrin or brass as required a decent fit and push in, job done.
                If it was larger dia stuff you would go about it opposite doing the insert first and boring i/d to size, maintains concentricity being in one go.
                #356806
                Vic
                  @vic
                  I was thinking of chucking something larger in the collet chuck then putting the screw in from the back for drilling but was concerned it might unscrew unless I used a left hand drill bit and run in reverse? Worth a try though if I do it up tight enough and take it easy with the drill. Will give that a try.
                  #356807
                  Nick Hulme
                    @nickhulme30114
                    You can put a lock nut on the front
                    #356810
                    Vic
                      @vic
                      Posted by Nick Hulme on 06/06/2018 21:33:22:
                      Ahah, didn’t think of that! Only trouble is the bolt is only 10mm long. Counterboring as you say though may do the trick.
                      Thanks folks, I’m a lot more confident of success now! smiley
