Myford Correct Oils
Myford Correct Oils
Home Forums General Questions Myford Correct Oils
Viewing 25 posts - 1 through 25 (of 49 total)
  • #327963
    Andy Beckett
      @andybeckett68581
      I collected my Myford Super 7 today, its in my log cabin but separated from the stand. As the floor is wooden I've put some ply underneath the stand and once I get my adjustable feet I'll level it up.
      Before I got to use it I want to ensure I have all the correct oils and in lubes in the right places. The old manual from 1956 speaks a different language to me so I'd like recommendations what I need to buy on a trip to Halfords please?
      #25639
      Andy Beckett
        @andybeckett68581
        #327970
        Thor 🇳🇴
          @thor
          Hi Andy,
          This is what Myford recommends. The Esso Nuto 32 is a hydraulic oil with a ISO VG of 32, any hydraulic oil of the same viscosity should be Ok. The thicker Slideway oil is used on the ways, cross-slide and topslide.
          Thor
          #327972
          Clive Foster
            @clivefoster55965
            Halfords won't have anything suitable.
            ISO 32 hydraulic oil with anti-wear additives for everything except the slideways. Thats a basic hydraulic oil readily available mail order or from specialists. I use Castrol Hyspin AWS 32 in my (not Myford) lathe 'cos its what I can get easily and its done me fine for over 25 years but there are many equivalents from other brands. No need to pay extra for the fancy high temperature, anti-foam et al properties.
            ISO 68 dual rated slideway / bearing oil for the ways and backgear train. Pukka way oil is too sticky for small lathes. Many brands but I use Castrol Magna BD 68. Excellent in the oil can for hinges and the "Honey Do" jobs too. Thin enough to flow (slowly) but stick enough to stay put for a year or more. But not in locks!
            Clive.
            Edited By Clive Foster on 19/11/2017 18:35:35
            Edited By Clive Foster on 19/11/2017 18:36:06
            #327973
            Andy Beckett
              @andybeckett68581
              Thanks Thor, your help is very much appreciated.
              #328039
                My lathe has been lubed with motorbike engine for the past 50 years or more since my old man bought it and still has almost not wear on it. I like the modern synthetic motorbike oils as they don't go gummy over time so slide very nicely.
                #328050
                john fletcher 1
                  @johnfletcher1
                  If you go to a ship chandler, agricultural part dealer or earth moving equipment dealer I think they will have what you are looking for.I have an equivalent list for oils and here are a few oils suitable for Myford lathe. BP Energol HLP 32, Castrol as Clive says, Gulf Hydrasil 32,Texaco Regal R&O 32, Shell Tellus 32,Mobil DTE Light. I take along a cleaner empty milk container and get a litre for about £2 or a little less. John
                  #328051
                  Chris Trice
                    @christrice43267
                    #328053
                    David Standing 1
                      @davidstanding1
                      Posted by Chris Trice on 20/11/2017 09:09:49:
                      Mail order is our friend. https://www.myford.co.uk/acatalog/Oils.html
                      And also a horrendously expensive way of buying exactly the same spec oil that can be obtained elsewhere for about half the price.
                      #328057
                      Andy Beckett
                        @andybeckett68581
                        Got the correct oil from the Bay, £10. A little concerning is the previous owner gave me a grease gun with the lathe and it appears he's been applying it via the nipples??
                        #328062
                        KWIL
                          @kwil
                          If he has applied grease, then you must clean it all out. Are you sure he was using grease or did it contain oil?
                          #328071
                          Andy Beckett
                            @andybeckett68581
                            It's got brown engineering bearing type grease. Cleaning it out sounds like fun? Hope it hasn't caused any damage.
                            #328077
                            Chris Trice
                              @christrice43267
                              Posted by David Standing 1 on 20/11/2017 09:14:56:
                              True but it is a source that solves his problem of not having any.
                              #328080
                              David Standing 1
                                @davidstanding1
                                Posted by Chris Trice on 20/11/2017 11:48:02:
                                So is eBay. If he has online purchasing ability, he will have access to the same oil at much cheaper prices.
                                Why throw money away if you don't need to?
                                #328094
                                Roderick Jenkins
                                  @roderickjenkins93242
                                  I understand that Halfords hydraulic jack oil is a standard ISO32. My Super 7 manual recommends a straight SAE30 motor oil for the rest. I am imagine that Halfords cheapest 5-30 will be fine.
                                  Rod
                                  #328123
                                    One of the world's great unexplained mysteries is why Myford fitted grease nipples to their lathes for oiling them rather than oil nipples, leaving a legacy of grease-gunged lathes and frustrated owners with leaky grease-guns (less than) full of oil.
                                    N.
                                    #328126
                                    David Standing 1
                                      @davidstanding1
                                      Posted by Neil Wyatt on 20/11/2017 17:56:07:
                                      N.
                                      I suspect a job lot of ex-MoD grease nipples available surplus in 1947, at a more than attractive price wink 2
                                      #328128
                                      Andy Beckett
                                        @andybeckett68581
                                        Thanks Neil, the manual is quite clear it requires a specialist oil, however, it's also quite clear the previous owner has used grease.
                                        So what do I do now, I really don't want to start stripping a lathe I haven't even used yet.
                                        Oil wise, what do I use to apply the oil seeing as a grease gun is not designed for this purpose?
                                        Any help appreciated.
                                        #328129
                                        duncan webster 1
                                          @duncanwebster1
                                          if anyone in the North West wants some Tellus 37 I can sell them some at a decent price. Bring your own container.
                                          #328130
                                          Martin 100
                                            @martin100
                                            It is so generations of owners of said lathe could spend hours and many tens of thousands of words about procurement and use of the bodged grease gun to oil their machine, said bodged grease gun is not made like it used to be, and owners should buy brand xyz and modify it etc.
                                            Boxford (and many others except Myford) Buy, grease the grease points now and again (or simply twist the grease caps) , oil the oil points now and again with an off the shelf oil can. The End
                                            #328131
                                            David Standing 1
                                              @davidstanding1
                                              Posted by Andy Beckett on 20/11/2017 18:07:33:
                                              Use one of these:
                                              Edited By David Standing 1 on 20/11/2017 18:18:53
                                              #328132
                                                Many other Myford users have ignored the manual and used grease, possibly many of them second owners who didn't get the manual.
                                                Lathes UK waltzes around various types before recommending ISO 32 hydraulic oil for everything except vertical slideways.
                                                #328134
                                                Andy Beckett
                                                  @andybeckett68581
                                                  Thanks David, all ordered.
                                                  Thanks Neil, so will it be ok to start using oil and leave the grease?
                                                  Sorry for all the questions, haven't touched a lathe since school!
                                                  #328138
                                                    Posted by Neil Wyatt on 20/11/2017 18:27:02:
                                                    … Of which there are not many on the typical Myford Lathe.
                                                    devil
                                                    David Standing 1
                                                      @davidstanding1
                                                      Posted by Michael Gilligan on 20/11/2017 18:46:12:
                                                      devil
                                                      Ooh, sharp Michael wink 2
