Trying to find 16mm slitting saw arbor for lathe
Home › Forums › General Questions › Trying to find 16mm slitting saw arbor for lathe
  • #23494
    Stevo
      @stevo
      #163707
      Stevo
        @stevo
        Hi All..
        Ive a couple of slitting saws with 16mm (exact) bore. I'm trying to find an arbor exactly 16mm – all I can find is 5/8 which is too small and the saw runs eccentrically!
        It will need a parallel shank as I use it in a lathe…
        Any help appreciated!
        Steve
        #163708
        roy entwistle
          @royentwistle24699
          Steve All due respects but you've got a lathe why can't you make your own ?
          Roy
          #163709
            RDG do a set of 3 that includes 16mm but they are not that hard to make.
            #163710
            Stevo
              @stevo
              I was waiting for that one wink
              Yes I could do of course Roy but not too much time available. I have one of those stepped ones which are really useful but only on an imperial size. If there was one off the shelf for a tenner or so I'll consider that !
              #163711
              Stevo
                @stevo
                OK Jason – why didn't I spot those ? Doh..
                #163712
                  Steve,
                  These folks look promising … But I doubt if they're a Tenner.
                  For occasional use, I would be tempted to make some oversize blanks and skim one [to size and concentricity] as and when required.
                  Edited slightly, having now seen the other postings.
                  Edited By Michael Gilligan on 16/09/2014 19:36:43
