Myford CNC Conversion Kit – Tony Jeffree
Home › Forums › Workshop Tools and Tooling › Myford CNC Conversion Kit – Tony Jeffree
  • #655572
    Samuel Langley
      @samuellangley71728
      I've recently acquired a Myford ML7/Super 7 CNC conversion kit from Tony Jeffree's design. From what I can tell, it's partially completed and only needs the actual leadscrew modifications ('part 1&#39 and Mach3 setup, of which the pulleys and belts are there. The cross slide pulley, leadscrew motor box, and controller are complete.
      The CNC control box is from DIYCNC.co.uk and within is their Uniport V2 controller. I couldn't tell you much else about the full controller setup. There are two other parts contained, top right in the pictures, which are internal grinding spindles placed into a housing with bolt fixing locations on the Myford cross slide. My guess is that the original user was going to convert it into a 2 axis milling setup, well capable with this Uniport controller.
      I was wondering if there's still demand for this sort of thing to be sold on as currently I've not got any interest in converting my ML7.
      http://www.jeffree.co.uk/pages/ml7-cnc/part-1-files/myfordcncpt1.htm
      http://www.jeffree.co.uk/pages/ml7-cnc/part-2-files/myfordcncpt2.htm
      http://www.jeffree.co.uk/pages/ml7-cnc/part-3-files/myfordcncpt3.htm
      http://www.jeffree.co.uk/pages/ml7-cnc/part-4-files/myfordcncpt4.htm
      #21047
      Samuel Langley
        @samuellangley71728
        #655590
        Ady1
          @ady1
          Mach 3 is still about as far as I am aware, the steppers look like nema 23s 3amp jobs which are ok
          a couple of controllers a power pack and a board all wired up and ready to go
          Bound to be a few who would fight over it on ebay, especially since the build files are still available
          Edited By Ady1 on 08/08/2023 09:24:48
          #655623
          Martin Connelly
            @martinconnelly55370
            As long as you have 16bit computers that will run XP or Win10 and have a USB port I don't think Mach3 is going to disappear very fast. It has been around long enough to be stable and a lot of people are using it without problems. I know there are some people who would like to improve threading due to the single pulse per rev causing issues on low power lightweight machines, but if you have back gear, a drive train with plenty of mass and a sufficiently powerful motor there is no problem. I think people who converted machines with a speed control that reduced motor power were the ones having the biggest headache with threading.
            Martin C
            #655630
            John Haine
              @johnhaine32865
              The Uniport is I think a parallel port BoB which also needs a USB connection to get +5v from the host. Mach3 needs a 32 bit processor to drive a parallel port, any 64 bit processor can only use a USB or Ethernet interface to a suitable motion controller. PCs with a parallel port must be pretty rare these days. However a USB motion controller such as the UC100 could be used with this to drive the parallel port input.
              Mach 3 is OK but any new user would be well advised to use Mach4 or UCCNC or similar with a USB or Ethernet interface.  M3 is long in the tooth and unsupported for getting on for 10 years.
              Edited By John Haine on 08/08/2023 13:40:45
              #655638
              duncan webster 1
                @duncanwebster1
                I've got a computer which has a parallel port. It is destined for the tip, so if anyone wants it come to north Cheshire and get it. Free, gratis and for nothing. If you really want to part with money a donation to the Sally Army. On security grounds I might take the hard drive out
                Edited By duncan webster on 08/08/2023 15:04:33
                #655661
                Ady1
                  @ady1
                  I think there are parallel port adapters about ported onto a usb connection
                  No guarantee that it will communicate 100% though, you have to buy and try
                  Edited By Ady1 on 08/08/2023 18:01:42
                  #655666
                  sam sokolik
                    @samsokolik60334
                    Posted by Ady1 on 08/08/2023 18:00:18:
                    usb to parallel port adaptors will not work in this situation…
                    sam
                    #655667
                    Ady1
                      @ady1
                      Here's a fancy one, seems to be for mach 3
                      #655670
                      Martin of Wick
                        @martinofwick
                        You can try to get a pukka UC100 USB to Parallel motion controller adapter if you want Mach 3 'big Button CNC' (for which you still have to pay a hefty licence fee). Find a reputable source of supply because it is said there are plenty substandard knockoffs about.
                        Or go down the Arduino UNO / CNC shield route wire up the drivers and PSU etc to it and use Grbl or any of the other free G code runners and run your machine off a laptop.
                        Much to my surprise, I managed to easily convert an old Chinese Mach 3 engraver/router with the arduino approach and I have no electronic knowledge whatsoever. Heaved all of the big boxes complete with parallel ports into a skip, never been so glad to see them go. Mind you, they were so old maybe they could have been flogged on line as 'vintage' post Turing computing equipment!
                        Edited By Martin of Wick on 08/08/2023 18:48:32
                        #655684
                        Martin of Wick
                          @martinofwick
                          So to answer your actual question, I am sure there would be a demand for the mechanical parts and drivers for anyone wanting to convert an M7 to CNC.
                          A good thread on github with a modified Grbl but requiring an Arduino Mega – Doubt if a UNO would have enough capacity for the extra control a lathe requires.
                          #655690
                          Martin Connelly
                            I said earlier 16 bit when I should have said 32 bit. I believe some 64 bit computers will not run Mach3
                            Martin C
                            Edited By Martin Connelly on 08/08/2023 19:39:08
                            #655693
                            John Haine
                              @johnhaine32865
                              Any 64 bit PC will run Mach3 with a USB or Ethernet motion controller, Win10 and 11.
                              GRBL has been used quite a few times on CNC lathes and I think there's a version called GRBLlathe. GRBL on an Arduino or something more powerful and ARM-based should be an interesting approach for a motion controller for M3 but one would need a Mach3 "plugin" that would involve getting the API details from Newfangled Solutions. They don't really want people using Mach3 any more (though they are pleased to sell it).
                              #655712
                              Samuel Langley
                                @samuellangley71728
                                Thanks all for your replies!
                                I'll likely be listing it on eBay soon, along with a link to this thread with all this amazing information.
                                #655905
                                Michael Callaghan
                                  @michaelcallaghan68621
                                  I have been using mach3 with usb connection for years. It’s not the mach3 program that stops people using usb it’s the breakout board they use. I have converted two lathes to run on Mach 3 it’s simple enough. The only pain I had was working out the steps per revolution etc, as it’s not automatic on the Mach 3 turn program, why I don’t know.
                                  #655907
                                  John Haine
                                    @johnhaine32865
                                    Posted by Michael Callaghan on 10/08/2023 12:12:05:
                                    Would be helpful if you could specify which BoB you use?
                                    #655915
                                    Michael Callaghan
                                      I use a CS-LABS Bob, however there are a few very good cheaper bobs on Amazon or eBay that work very well.
                                      #655921
                                      John Haine
                                        @johnhaine32865
                                        Thanks, so a combined motion controller and BoB.
                                        #655933
                                        Michael Callaghan
                                          The CS-LABS unit is, the cheaper bobs on eBay not. However I have found both very easy to set up and use.
                                          #657187
                                          Samuel Langley
                                            @samuellangley71728
                                            Hi all,
                                            I have listed this kit on eBay if anyone who comes across this thread is interested.
                                            https://www.ebay.co.uk/itm/266377098611
