Small slitting saws
Small slitting saws
Home Forums Workshop Tools and Tooling Small slitting saws
  • #375268
    ronan walsh
      @ronanwalsh98054
      I am looking for a small slitting saw, 1 1/4" x .082", anyone know where i might buy one ? I have looked on ebay etc, but this size is smaller than any i can find.
      #19105
      ronan walsh
        @ronanwalsh98054
        #375273
          Is the 1 1/4” dimension diameter or arbor size?  2mm is close.
          Edited By not done it yet on 09/10/2018 22:24:23
          #375274
          Emgee
            @emgee
            Try searching for Dremel 32mm saw blades, many available but perhaps not the exact thickness you want,
            you may be able to double up 1mm thick blades for close to your desired width.
            Emgee
            #375276
            ronan walsh
              @ronanwalsh98054
              Yes 1 1/4" is the diameter of the blade itself, not the arbour hole. I will look at the dremel blades.
              #375277
              Mike Poole
                @mikepoole82104
                Chronos have 20mm 25mm and 40mm, if the thickness is critical perhaps a thicker one could be ground down.
                #375287
                SteveI
                  @stevei
                  Ronan,
                  CR Tools in Sheffield have several options very close to what you want.
                  I have no connected except as a satisfied customer.
                  Steve
                  #375349
                  John Paton 1
                    @johnpaton1
                    What bore do you need? I can have a look in my box of slitting saws as I no longer use the very small ones (used to when I had a Myford), some are really small diameter and from memory I think most were about 1/4" bore.
                    #375358
                    pgk pgk
                      @pgkpgk17461
                      CTC do a range of small slitting saws cheap enough for a punt. The arbor they provided was rubbish but that's easily knocked up.
                      Edited By pgk pgk on 10/10/2018 15:51:42
                      #375401
                      ronan walsh
                        @ronanwalsh98054
                        Arbour size is not really important, as i can make up a simple one, its for a one off job.
                        #375405
                        speelwerk
                          @speelwerk
                          Arntz **LINK**have a good metric range of small slitting saws, it is a German based compagny but curiously only the Dutch and the US agents have the small ones. The direct link does not work, you find it by; Circular Saw Blades – Metal Circular Saw Blades and then at the end of the page you go to DIN 1837-1838. The 2 mm thickness will probably make a slit around 0.02 mm wider. If you clamp two of 1 mm together it will be less accurate and very close to your desire and if you want it a little wider you can clamp a shim from 0.02 mm or more in between. Niko.
                          Edited By speelwerk on 10/10/2018 22:02:32
                          #375569
                          John Paton 1
                            @johnpaton1
                            Ronan
                            I have just been through my tin of small slitting saws.
                            I don't have an 982" one but have a pair of thinner ones that gang up to 087 if that is near enough for you.
                            The blades are 1.75 diameter with 5/8 bore. Both ares HSS one by Buck and Hickman, the other Wolferal.
                            Would these do the job?
                            ronan walsh
                              @ronanwalsh98054
                              Posted by John Paton 1 on 12/10/2018 00:20:25:
                              Ronan
                              Thanks for taking the time and trouble to do that John, but the OD needs to be 1.25", the thickness is not so critical, around the 2-3 mm mark, but the diameter is. Thanks again.
                              #375975
                                Ronan, what are you using the saws for?
                                Would it be possible to make a simple cutter from a slice of silver steel or piece of gauge plate with say 8 teeth that could easily be mounted on an arbor or what about grinding down a cheap 1 1/4" dia woodruff cutter to the required width?
                                Edited By JasonB on 14/10/2018 20:52:21
                                #375978
                                  Some on the big river. Probably not what you want or of decent quality, this set contains one cutter of 32mm diameter, but is cheap and blades could possibly be ganged together for extra width? Only posted it because we have no idea of the material to be cut…
                                    There's this one I made from 1 1/4" silver steel. Ended up about 29.9mm diameter, 2.65mm thick.
                                    I wanted to cut holding down slots in the sides of a cast iron toolmaker's vice. Did a great job and since I've used it for a few other things. Looks crap, but works fine, just needs to eb run gently as it's carbon steel.
                                    You could copy it as Jason suggests, or if you are really stuck and it's near enough on diameter I could post it.
                                    #375981
                                    ronan walsh
                                      @ronanwalsh98054
                                      Posted by JasonB on 14/10/2018 20:51:06:
                                      It is to mill a semi-circular slot into a block of steel about 8mm square. There is a piece that fits through the slot and when the 8mm piece lifts up and down, the cross piece, which is mounted on a pin, is used on the opposite end to lift something else, like a miniature see-saw. This is for a job for a college students project, i am not fully aware of what it does, and i would rather buy a cheap slitting saw than waste more time making yet another piece. Thanks all.
                                      #375998
                                      speelwerk
                                        @speelwerk
                                        Is it not possible to make the cross piece fit the slot, that way the diameter of the saw is not critical. Niko.
                                        Edited By speelwerk on 15/10/2018 00:33:48
                                        #376848
                                        ronan walsh
                                          @ronanwalsh98054
                                          As an addendum to this thread, i found what i wanted on the site below. The tap and die company in Wood Green London. Has anyone dealt with this company ? Ok to deal with ?
                                          http://www.tapdie.com/html/slitting_saws-_slitting_saws_inch-_slitting_saws_metric.html
                                          #376879
                                            The minimum order might make it a bit expensive? But, if needs must….
                                            #376887
                                            Mike Poole
                                              @mikepoole82104
                                              I made a personal visit and was made very welcome, pleased with my purchases as well. I have also purchased online and it all went smoothly.
                                              #376898
                                              Brian H
                                                @brianh50089
                                                Posted by ronan walsh on 20/10/2018 21:18:15:
                                                Excellent company, very helpful. No connection.
                                                Brian
