Myford M Lathe Speed
Home › Forums › Workshop Tools and Tooling › Myford M Lathe Speed
  • #319449
    James Jenkins 1
      @jamesjenkins1
      Hi all,
      I am going to be powering my Myford M using a 1HP 2,800 RPM motor. It's a DC motor, so I will be using a PWM to controller the speed, together obviously with the back gear. PWMs are great, but the low speed torque isn't quite there – but as I say the back gear should take care of that. I just want to use one gear ratio and then use the PWM for speed control.
      Can you please tell me what you consider to the be optimum top speed for the lathe? From that I can workout which drive belt wheel to use and the size of the drive pulley.
      Many thanks,
      James
      #18674
      James Jenkins 1
        @jamesjenkins1
        #319458
        David George 1
          @davidgeorge1
          Hi James as the spindle is running in plain bearings you should not over speed them. this is the original speed as on my lathe M type.
          MYFORD / DRUMMOND M TYPE LATHE SPINDLE SPEEDS
          600 RPM SPINDLE PULLY
          MAIN DRIVE
          BACK GEAR
          850 RPM
          100 RPM
          600 RPM
          70 RPM
          400 RPM
          50 RPM
          330 RPM SPINDLE PULLY
          450 RPM
          50 RPM
          300 RPM
          40 RPM
          200 RPM
          20 RPM
          David
          #319462
            I've got my M type geared to run about 950rpm in "top", 400 in "second" and 200 in low. Countershaft speed is about 400rpm to achieve this. Works fine.
            I previously had it geared (pulleyed?) to run about 1200 rpm in top but found that the resulting 600 in second and 300 in low were a bit fast for most of the work I was doing. Bearings seemed to stand up OK to the 1200rpm.
            #319477
            James Jenkins 1
              @jamesjenkins1
              Hi all,
              Very helpful and just what I was looking for – thank you. I'll aim for about 850 RPM with my gearing, as the actual voltage of the system is often a touch higher than the nominal 36v – due to the solar panel voltage – so the resulting speed is higher. I am hoping to avoid the need for counter shafting using the PWM – but only time will tell whether it can can deliver the power in lower speeds and whether I can get the pulley ratio reduction without it. The setup works on my pillar drill without any trouble, but the driven pulley is much larger.
              I will let you know how I get on.
              James
              #319487
                It'll be interesting to see how the 2800rpm motor performs torque-wise at 400 rpm or so without a countershaft. Keep us posted.
                #368511
                James Jenkins 1
                  @jamesjenkins1
                  Hi all,
                  I am finally getting around to doing this, having bought a Myford M countershaft. As I have mentioned before the motor I am using is a 2800rpm motor and the countershaft has a 9" A section pulley on the end (plus an 8" one). I am thinking of using a 2 1/4" driver pulley on the motor, which will give a countershaft speed of 700rpm. I know this is a touch higher than the usual 600rpm, but I will have PWM control to reduce this down to the required speed, as well the belt changes on the mandrel and the back gear.
                  Is there likely to be any issues with going from 2 1/4" to 9" in terms of belt grip, or should that be ok? Any minimum pulley distance to aim for?
                  Many thanks,
                  James
