Syil X4 bigger bed
Syil X4 bigger bed
Home › Forums › Workshop Tools and Tooling › Syil X4 bigger bed
  • #299429
    Antony Powell
      @antonypowell28169
      Hi All
      I am finding the bed on my X4 to be too short, by the time I have my 4th axis and opposing tail stock fitted my working area is severely reduced.
      The simplest way to fix it I can think of would be to bolt a longer tee slot plate on top of the original bed.
      I don't need more working area than is already available just to recover the lost area / dead space taken by the 4th axis and tail stock
      Does anyone have either a better / easier / cheaper suggestion or a supplier of a good quality tee slot plate
      thanks
      Tony
      #18526
      Antony Powell
        @antonypowell28169
        looking to extend
        #299433
          You could just fix a X3 long table ontop of the existing one and gain an extra 150mm which is probably about the only source of a tee slotted plate/table you will find.
          Other option would be to make a plate to hang the 4th axis off one end that could just use drilled and tapped holes. Then make a riser piece for the tailstock so it can still slide along the existing tee slots.
          #299436
          Ketan Swali
            @ketanswali79440
            Hi Jason,
            If Antony was to consider your suggestion, ARC would not be comfortable to supply the long table to him for the purpose he intends to use it for.
            There are too many variables to consider, and we would'nt be interested to get into a discussion on the subject for his purpose of use.
            Ketan at ARC.
            #299438
            ega
              @ega
              Ketan Swali
              Whilst I understand your position I find it a bit disappointing; I have been considering the various tee-slotted items you have with a view to use on the plain cross slide of my lathe.
              I have had numerous items from you and not surprisingly never been asked what I wanted them for.
              I would add the general comment that I very much welcome your willingness to get involved in this forum.
              #299441
                No problem Ketan, I'll just have to find something else to sugget to get my commisionwink 2
                Thinking about it a bit more I don't think the underside of the table is machined true to the top so it would not work anyway and its thicker than really needed so would reduce z height.
                Stick with the other suggestion of a plate and riser block
                Edited By JasonB on 24/05/2017 11:35:03
                #299443
                Journeyman
                  @journeyman
                  How about an aluminium tooling plate? 20 – 25mm thick, drill and tap pattern of fixing holes. Allow to overhang the end of the table by whatever you need. Underside of the overhang could be supported / stiffened by some bolt on beams. Pattern of holes can be what you need and probably as easy to use as T-slots. Think I saw a video of something similar being made on a Tormach for use on that mill.
                  Edit: Have a look ***HERE*** post No.16
                  Edited By Journeyman on 24/05/2017 11:25:59
                  #299451
                  Antony Powell
                    @antonypowell28169
                    I have found this company on line
                    https://vacuumtables.co.uk/t-slot-plates/steel-t-slot-plates-finely-milled/steel-t-slot-plate-2020-finely-milled
                    I'm waiting for the cost of one 800 x 200mm
                    they do both steel and ali
                    they are on ebay also item number 172257968088
                    they do state suitable for bolting on to of the bed
                    Tony
                    Edited By Antony Powell on 24/05/2017 12:04:48
                    Edited By Antony Powell on 24/05/2017 12:10:02
                    #299453
                    Antony Powell
                      @antonypowell28169
                      Thanks Journeyman that's another option…
                      tony
                      #299454
                      Journeyman
                        @journeyman
                        Tony a chunk of Eco-cast aluminium plate (ground both sides) 600mm x 200mm x 20mm £50 + VAT from Aluminium Warehouse. You do however have to add your own holes, still that's easy with CNCsmiley
                        Ketan Swali
                          @ketanswali79440
                          Posted by ega on 24/05/2017 11:03:12:
                          Ketan Swali
                          ega,
                          What you would be dealing with would be small sizes with small number of variables to overcome.
                          For the long table, it is not machined underneath true to the top (as Jason said) to enable it to be used in the way Tony would like, as it is not designed for that purpose. So that is one variable – which he would need to mill, along the full length… ideally in one long pass, unless he wishes to consider shimming. Another variable is his own milling table, which may have a certain amount of twist/bend, along the full length of travel. Depeding on Tonys ability/wish/desire/acceptability, he may or maynot want to/be able to carry out this work.
                          Small lengths of T sloted tables are easily dealt with. Long tables such as these is a different story. You are right in so far as we do not ask 'what does one want a product for' in most cases. However, for certain products we do ask, pre-sale, and there are occassions where we politely decline to supply.
                          Specifically with reference to the X3 long table, we always speak to the customer pre-sale, becasue they are not a retrofit, even to a standard X3. For those persons, we have to explain to them that the original table on thier X/SX3 is a custom fit, and to fit a new table, there may be some scraping involved – to their saddle for example, to make the new table fit their exisiting X3. Keeping this in mind, we wish to avoid inviting problems when this product is considered for an alternative use.
                          Ketan at ARC.
                          #299456
                          Paul Lousick
                            @paullousick59116
                            I do not have a 4th axis on my mill but have a similar problem with not enough length to machining a shaft between centres using a rotary table (mounted vertically) and a tailstock centre. I plan to use a plate bolted to one end of the X-table and mount the RT on it (similar to Jason's photo). The top and bottom sides of the plate have to be parrallel and I will have key slots and keys to align the plate and the rotary table. No need for T-slots.
                            Paul
                            #299466
                            ega
                              @ega
                              Ketan Swali:
                              Thank you for taking the trouble to explain.
                              #299467
                              geoff adams
                                @geoffadams14047
                                Hi
                                got my x4 just after xmas this year first thing i did was order a .5"x 20×10" alloy plate drilled and tapped m8
                                reamed 6mm in a grid pattern the 4th axis now sets outside the work area giving a greater working area same with tailstock
                                the vice i drilled and reamed to suit grid now no need to clock vice everytime
                                got rid of original guard and made my own all works great
                                over the moon with my machine how are you getting on with yours
                                all th best geoff
                                #299469
                                Antony Powell
                                  @antonypowell28169
                                  Hi Geoff
                                  Yes like it , not had any problems as yet only too busy to learn g code properly so limping along a bit still
                                  had it for over a year and it performs the jobs it was bought for flawlessly and repeatedly.
                                  Like the idea of a full plate as it should improve the rigidity of the bed and keep everything level as well
                                  binned the original guard as well it just got in the way
                                  Tony
                                  #299472
                                  geoff adams
                                    @geoffadams14047
                                    Hi Tony
                                    will post pics of my subplate tomorrow need my boy to do this
                                    learn g code he hard way back in the 70s early 80s only a calculator no computers then making aircraft instruments
                                    only just got the hang of emachineshop cad and cambam cam does made things easy
                                    been out of engineering for 30 odd years got back into it on retiring 3 years ago
                                    making model steam engines
                                    Geoff
                                    if i can help give me a shout
                                    #299704
                                    geoff adams
                                      @geoffadams14047
                                      Hi Tony
                                      sorry no pics my boys having a bit of a problem they keep uploading upside down
                                      we will keep trying
                                      Geoff
                                      #299998
                                      Antony Powell
                                        @antonypowell28169
                                        Hi Geoff
                                        Yes I had that problem, i uploaded them upside down so that when the came online they were right side up !!
                                        no idea why I'm not big on computer problems it's mainly guesswork.
                                        I bit the bullet and ordered an 800 x 200 mm vac plate with full tee slots from the company I found on line perfectly flat both sides so should bolt on OK probably expensive by most peoples standards at £164 inc vat but i don't have the time to mill my own slots or drill a hundred holes and tap em out.
                                        Will post some pics when it arrives and i get it fitted
                                        Tony
                                        #300008
                                        geoff adams
                                          @geoffadams14047
                                          Hi Tony
                                          sorry pics still upside down one shoud be ok part i made today
                                          hope these help
                                          Geoff
                                          #302238
                                          Antony Powell
                                            @antonypowell28169
                                            This image shows the plate before fitting to the bed
                                            And this one after the install, makes a big difference and allows items twice the origional length to be worked on using the 4th axis
                                            Tony
                                            Edited By Antony Powell on 12/06/2017 16:39:06
