Steam pipework SWG
Steam pipework SWG
Home Forums Locomotives Steam pipework SWG
  • #391124
    SomersetSimplex
      @somersetsimplex
      I’m tidying up the pipework on a Simplex, most of which is 3/16”. What SWG should I use / is there a minimum recommended? The supplier I’m intending using lists 16, 20 & 22 SWG.
      GAVIN
      #1789
      SomersetSimplex
        @somersetsimplex
        #391125
          May want to take a look at this recent thread on the subject
          #391134
          Former Member
            @formermember19781
            #391166
            SomersetSimplex
              @somersetsimplex
              Thanks Jason. I tried searching SWG and a couple of other terms, but obvoiusly not the correct ones.
              #412654
              SomersetSimplex
                @somersetsimplex
                Just following up on this, is there any reason not to use annealed copper pipe- it is cheaper than the straight lengths and comes in a coil so longer single lengths?
                #412748
                Ian S C
                  @iansc
                  It's easier to use straight lengths, and bend them, rather than trying to get the coiled tube straight, curves where it should be straight look awful, you would find out about pipe work if you modeled an NZR locomotive, all the pipe work exposed all over the boiler.
                  Ian S C
                  Edited By Ian S C on 05/06/2019 13:27:53
                  #412793
                  duncan webster 1
                    @duncanwebster1
                    Gavin
                    I've got a load of brand new copper pipe I'm trying to sell on behalf of a model engineer who has had to give up due to ill health. It will be a lot cheaper than retail. If you're interested, send me your email address by pm and I will send you a list
