Identifying Internal threads
Home › Forums › Workshop Techniques › Identifying Internal threads
  • #519360
    Vic
      @vic
      Anyone got any tips on how I might Identify an internal thread on a machine? Its not metric and I don’t have any imperial bolts of a likely diameter to try. I’m not in the workshop at the moment but I think it’s likely 5/16 or 3/8 something or other! I’ve got some thread pitch gauges but not too easy to use on internal threads.
      #16235
      Vic
        @vic
        #519361
          Screw a suitable diameter of wood or plastic into it
          … unscrew, and measure the pitch of the male thread
          Pete.
            @pete-2
            Use some polymorph, it's cheap, and reusable
            #519367
            Tony Pratt 1
              @tonypratt1
              Okay not easy with your limited 'equipment',what m/c is it & how do you know it's not metric? Give us the manufacturers name that will be a good clue.
              Tony
              #519378
              Vic
                @vic
                Update. I’ve seen reference to the size in the manual for a later model so I have a staring point now. Apparently it’s UNC.
                #519387
                Tim Stevens
                  @timstevens64731
                  I have had success using a simple wooden toothpick. Break off the sharp end, and slide the pick around the thread while keeping it in line with the axis, using pressure from a finger (etc). This should result in a series of grooves or dirty lines (or both) along the pick, so you can measure how many fit to an inch or to 25mm. Then a moment's calculation should reveal the threads-per-inch, or the pitch in mm.
                  Cheers, Tim
                  #519401
                  David Marks 2
                    @davidmarks2
                    If you have a set of Letter series drills you should be able to get a good idea of the core diameter of the thread by inserting the shank of the drill into the hole. Regarding the thread profile and TPI, a small amount of car body filler placed into about 30 – 40% of the thread works. Due to the thread shape it lifts out very easily.
                  Home › Forums › Workshop Techniques › Topics
