Using Counterbores
Using Counterbores
Home Forums Workshop Techniques Using Counterbores
Viewing 25 posts - 1 through 25 (of 34 total)
  • #477531
    Colin Heseltine
      @colinheseltine48622
      I am intending to counterbore two holes which will have M5 caphead bolts located in them. The holes are drilled M5 and the bolt fits nicely. I have a set of very good quality counterbores with the usual range of sizes and several individual counterbores.
      The issue I have is that the locating spigot on all the counterbores are larger than I would have expected. i.e I would have expected the M5 counterbore to have a 5mm dia spigot but it is around 5.23mm. Is this 5.23mm diameter the correct sized clearance hole for M5.
      Colin
      #16168
      Colin Heseltine
        #477533
          Yes, they are intended for generous clearance holes, you can get some that use a smaller range but still more than nominal.
          Think M5 standard is 5.3mm clearance.
          #477536
            If you want ‘toolmaking’ tolerances for capheads …
            avoid the ISO Metric system and use Imperial fasteners.
            … I will leave you to find the comparative proportions angel
            Edited By Michael Gilligan on 04/06/2020 20:37:47
            #477540
            Tony Pratt 1
              @tonypratt1
              Posted by JasonB on 04/06/2020 20:27:17:
              Jason is correct & another point is you do want clearance around a screw as generally they are not used as a location component.
              Tony
              #477541
              Martin Connelly
                @martinconnelly55370
                I've looked through the British Standard for metric threads and there is no mention of clearance holes. The tables in my Zeus books say 5.1mm is the clearance drill for M5.
                Martin C
                #477542
                Chris Evans 6
                  @chrisevans6
                  Most (all?) of my counterbores are also bigger around the head than I would like. One day if I can be bothered I will spin them down on the cutter grinder. Got to get energy levels back after a recent stroke first though.
                  #477544
                  John Baron
                    @johnbaron31275
                    Hi Guys,
                    One thing that that needs to be accounted for when counter boring for cap head screws is that the shoulder under the head is a fraction larger than the clearance diameter. So the counter bore pilot is bigger to allow for that.
                    Edited By John Baron on 04/06/2020 21:14:27
                    #477546
                    HOWARDT
                      @howardt
                      Cap heads have a radius under the head, the clearance hole diameter should clear this. Therefore the clearance hole is the screw diameter +twice the radius under the head + tolerance on position. Of course in the model world you just ignore all that, make the hole as tight as you want on the screw diameter and tighten the screw.
                      #477571
                        Colin,
                        It may be useful to look at this thread from 2017 : **LINK**
                        https://www.model-engineer.co.uk/forums/postings.asp?th=124417&p=1
                        Edit: or this one, from 2015
                        https://www.model-engineer.co.uk/forums/postings.asp?th=107996
                        Edited By Michael Gilligan on 04/06/2020 23:15:58
                        #477574
                        Colin Heseltine
                          Michael,
                          Thank you for that link. Very useful information.
                          Colin
                          #477594
                            Thanks Michael, I knew there was a standard
                            I did see some counterbores with 5mm pilot and 8.7mm head for those wanting a really close fit but they did have larger head sizes too. There is also the option to get counterbores with removable pilots so you can make and fit one to whatever size you want.
                            #477629
                            Bo’sun
                              @bosun58570
                              Colin,
                              If you desperately want a "size for size" fit you could still use the counterbore tool you have, providing the pilot length is shorter than the depth below the counterbore. If that makes any sense? Simply drill the pilot diameter depth to the length of the pilot + the depth of the counterbore. The rest of the hole diameter can then remain at 5mm.
                              Hope that helps.
                              #477649
                              Vic
                                @vic
                                From a purely aesthetic point of view standard metric counterbores don’t produce a very neat result. I’ve therefore used a variety of other tools including some home made ones to produce something that looks a bit better.
                                #486818
                                MC Black 2
                                  @mcblack2
                                  Does anybody know where I might buy Fractional Inch or BA Counterbores, please?
                                  I have a set of metric counterbores and the Pilots are far too large for the nominal size holes.
                                  I would like to investigate using Inch fractional or BA sizes.
                                  Very many thanks for your help
                                  #486831
                                    I think you will find imperial just the same eg a #5-40UNC which is very close to 5BA would have a pilot of 0.140". have a look at MSCdirect.co.uk
                                    #486836
                                    Paul Lousick
                                      @paullousick59116
                                      As mentioned, the standard counterbore cutters are made for general industry which uses a bigger clearance hole for bolts. Bolts are not normally used for the precision location of parts and the tolerance on position of holes is not what we would expect in a tool room. Often just measured with a tape measure or rule and centre punched for position. Having larger clearance holes for the bolts allows mating parts with shightly different hole positions to still be assembled.
                                      Easy to make your own counterbore cutter out of tool steel. Like a D-bit with a locating spigot.
                                      Paul
                                      #486849
                                        The first six lines in the table on p27 cover counterbores for #4 and #5 caphead screws
                                        https://www.bsaregalcuttingtools.co.uk/downloads/download.php?id=2
                                        Very nice tools, but a little pricey for hobby use.
                                        Edited By Michael Gilligan on 21/07/2020 09:24:48
                                        #487014
                                        Paul Lousick
                                          @paullousick59116
                                          Home made counterbore made by AdrianR in a previous post
                                          MadMike
                                            @madmike
                                            I have over the years found that the quality of commercially available cap screws has deteriorated, particularly if they are sourced from China. As I use them on parts for my motorbikes and on friends bikes, I make two mods. Firstly I mount them in a collet, and lightly remove the radius that has grown over the years where the head meets the main shank. Then I turn the outer diameter of the cap head to make it truly round and concentric with the main bolt shank. Over the years I have made and/or sourced counter bore tools to suit the modified head dimensions. This means a much tighter fit and a much more precise appearance to the finished work.
                                            #487029
                                              I don't think I would want to ride one of your bikes, the radius where head meets shank is to remove stress risers that could lead to fracture. This is actually one reason the clearance hole is larger than teh shank so that the head bears on the bottom of the counterbore and the radius does not foul a sharp edge.
                                              #487030
                                                While counter-bores are good, if of the required size needed, are they really needed if a DRO is fitted? Seems simple enough to sort out the counterbore with a suitably sized end mill immediately after drilling/tapping (if only a very few to do) or returning to DRO settings for the hole (if several are required).
                                                Much the same with countersinks as well?
                                                #487036
                                                  Posted by not done it yet on 22/07/2020 07:19:22:
                                                  While counter-bores are good, if of the required size needed, are they really needed if a DRO is fitted? […]
                                                  That rather depends on the the job at hand
                                                  “Horses for Courses”
                                                  Paul Lousick
                                                    @paullousick59116
                                                    If you counterbore after drilling each hole and don't move trhe table, a DRO is not required.  An end mill does not produce a flat surface, square to the axis of the hole but not normally a problem
                                                    Paul.
                                                    Edited By Paul Lousick on 22/07/2020 08:30:02
                                                    #487050
                                                    AdrianR
                                                      @adrianr18614
                                                      How embarrassing, having my counterbore quoted. Don't make one the same as mine, it has a numpty mistake, it runs backwards. What is worse I sharpened it three times trying to make it cut, before I realised my mistake.
                                                      Once the reverse button is pressed it cuts a perfect counterbore, lot cheaper than buying a set too.
                                                      Adrian
