Oddball inverter
Oddball inverter
Home Forums Manual machine tools Oddball inverter
  • #539236
    duncan webster 1
      @duncanwebster1
      My little Cowells lathe is driven by an 80W 3phase motor. The VFD is Mitsubishi SC A2 400M, which is reckoned to drive up to 400W motors. I've checked that the motor is set up in Delta.
      I've just measured the power at the lathe spindle, and I can't get more than 34W, see table below
      Speed RPM Torque Nm Power W
      1846 0 0
      1670 0.148 26
      1500 0.217 34
      with the speed control set to about half way I get
      880 0 0
      793 0.091 7.5
      668 0.183 13
      I don't think you get to set parameters like current with these devices, anyone got ideas as to why it's not producing the expected power? I wouldn't have thought it was losing that much in the lathe bearings.
      Oh and if you're wondering why I've got a three phase motor on a little machine like this, it came as part of a deal.
      #14225
      duncan webster 1
        @duncanwebster1
        #539277
        mgnbuk
          @mgnbuk
          I have yet to come across an inverter that does not require the input of the basic motor parameters (voltage, FL current, frequency & base speed ) – these seem to be the basic minima to get up and running ? FL current would be particularly important in your case of operating a drive with a motor a long way below the drive capability.
          No experience of a Cowells, but are they not plain bearing spindles so maybe higher drag than rolling element bearings ?
          Nigel B.
          #539286
          noel shelley
            @noelshelley55608
            VFDs are all the rage now – but there not a new idea. I have a 1.5Hp unit by mitsubishi from 1990. I have not used it but apart fom speed control there may not be much else. Have you tried contacting newton tesla, some speak highly of them, they may be able to help. Noel.
            #539290
            Clive Foster
              @clivefoster55965
              Duncan
              I got a couple of Mitsubishi inverters from Gavin Osman many years ago and have a vague memory of being told to be careful when adjusting parameters as it was quite easy to inadvertently put the beasts into a low power "test mode". Presumably provided so things could be made to go round without risking releasing magic smoke if jam ups occurred and other load related parameters were vastly in error.
              Apparently the manual was "less than clear" about this. (Everything else too I reckoned. The manuals in the box were about half the size of the VFD itself.)
              #539294
              Joseph Noci 1
                @josephnoci1
                Duncan,
                Cannot find that drive on internet – do you have the manual?
                From experience on my Lathe's VFD the behaviour may be due to the output voltage to frequency settings being incorrect. A start is max V @ 50Hz and dropping to 80% V @ 20Hz..
                Unlikely to be a too-low max current setting as that would probably trip the VFD.
                Joe
                #539295
                  Presumably power and torque are being measured with a dynamometer? Most excellent!
                  Do you have a domestic wattmeter or – more accurate – a multimeter reading AC amps. Be interesting to compare the input watts with the output power. If the inverter is drawing less than 80W at full load, then probably a parameter setting problem; if more than 80W, then either the electronics are horribly inefficient, and/or the lathe is wasting power in drive train. Does the power output at the spindle change after the lathe has thoroughly warmed up? (Cold plain bearings are notoriously sticky.)
                  Measuring input power to my 1.5kW WM280, it's difficult to take a cut heavy enough to fully load the motor. With carbide the resulting spray of red-hot chips takes all the fun out of machining, and I'm not convinced the lathe is rigid enough to work that hard and maintain accuracy. It's a hobby lathe!
                  More interesting though is the extra load imposed by engaging the banjo in fine feed and taking the lead-screw gearbox out of neutral. This takes 200W extra input with the lathe idling. Roller bearings on the motor and spindle, not sure what's inside the gearbox, but otherwise plain bearings all the way!
                  Michael Briggs
                    @michaelbriggs82422
                    Duncan, I may be able to help if I could find the manual for the VFD. I have searched for it and can't find anything for the SC A2 400M.
                    Michael
                    #539301
                      Posted by duncan webster on 11/04/2021 21:57:39:
                      My little Cowells lathe is driven by an 80W 3phase motor. […]
                      I've just measured the power at the lathe spindle, and I can't get more than 34W …
                      Forgive me for asking the blindingly obvious question, but:
                      How [in detail] is that 80W specified ?
                      You may find that your 34W measured power at the spindle is entirely reasonable.
                      Could you rig something to test the power at the motor shaft ?
                      P.S. … it is not unusual to specify motor output power ‘at stall’
                      Edit: some decades ago,  I used one of these:
                      https://www.magtrol.com/product/dial-weight-dynamometers/
                      Edited By Michael Gilligan on 12/04/2021 11:05:35
                      #539309
                      John Haine
                        @johnhaine32865
                        Posted by Michael Gilligan on 12/04/2021 10:48:33:
                        ?? Surely when stalled speed = 0, so power=torque x speed = zero too?
                        #539314
                          The inverter may have a power readout mode. If you can get it to do this, then the information will be helpful. It (obviously) should be less than the total power going in to the inverter and more than the power at the spindle.
                          If operating under good condition you should see an efficiency approaching about 90% at each stage, so the motor output should ideally be 'approaching' ~80%.
                          Then there's the losses in the machine, it seems excessive for that much power to disappear in the mechanical drive train, and a few tens of watts should be enough to make a small lathe noticeably warm.
                          #539322
                          Andy Carruthers
                            @andycarruthers33275
                            Have you tried disconnecting the drive to spindle and measuring with just the motor running – and does the motor get warm / hot?
                            #539342
                              Posted by John Haine on 12/04/2021 11:07:05:
                              Yes … hence the use of quotation marks.
                              [quote]
                              • Magnetically coupled hysteresis brake provides smooth torque application independent of shaft speed. This permits testing motors from no load to locked rotor or armature.
                              Edited By Michael Gilligan on 12/04/2021 13:55:12
                              #539385
                              duncan webster 1
                                @duncanwebster1
                                The motor is by Exico exico an industrial type, so I'd expect the power quoted to be output. Part # is 1254689
                                Calling my set up a dynomometer is being kind, I call it a lash up, but it works, a bit of wood, the kitchen scales and a Chinese tacho with the magnet stuck to the chuck.
                                The photo of the motor plate is not readable, the details are
                                400/230V
                                cosphi 0.74
                                A 0.31/0.54
                                I think this means input power is 400*0.31*sqrt(3)*0.74=158W
                                here's a couple of pictures of the VFD, the only adjustments are for acceleration and thermal cut out
                                I've got the manual, it says nothing useful. I'll try Newton Tesla tomorrow
                                #539446
                                Ian Parkin
                                  @ianparkin39383
                                  That’s strange I’ve never seen a VFD where the input terminals are marked R,S,T usually they are L1,L2,L3 if 3 phase or L1,N if single
                                  #539459
                                  Ian Parkin
                                    @ianparkin39383
                                    Is it a 400v inverter? Rather than a 200v one ..is it expecting 3 phase in? Some will run on 240v on 2 phases
                                    #539462
                                      Revel in your moment of fame, Duncan
                                        Posted by Ian Parkin on 13/04/2021 07:23:52:
                                        Not that unusual, there are several conventions kicking about including U,V,W; R,Y,B; T1,T2,T3; A,B,C; 1,2,3 and probably others. I've a vague memory RST is a German acronym. R,Y,B refers to Red, Yellow, Blue, which is an obsolete wiring colour code but I believe the others, including L1, L2, L3 are just sequences. We need an expert on the international history of 3-phase labelling systems!
                                        Oldiron
                                          @oldiron
                                          I have 2 HY inverters both are marked RST for input & UVW for output. I also have a VFD with no makers marks and that also is marked RST & UVW.
                                          regards
                                          #539555
                                            Posted by SillyOldDuffer on 13/04/2021 14:34:37:
                                            I am far from being an expert … but I did find this: **LINK**
                                            https://www.eevblog.com/forum/beginners/r-s-t-l1-l2-l3-u-v-w/
                                            [just to add to the confusion]
                                            Ian Parkin
                                              @ianparkin39383
                                              My mistake i meant marked as RST for a single phase vfd
                                              #539573
                                              duncan webster 1
                                                @duncanwebster1
                                                Been busy doing grand dad impressions all day, but just had time to measure input current (single phase from the mains). No photo as that really was a lash up (take the fuse out of the plug and put attach the DVM to the clips, it's only dangerous if you touch it).
                                                No load on lathe 0.3A
                                                loaded enough to slow it down significantly 0.7A.
                                                If it were delivering 0.54A to the motor I'd expect at least 0.93A, more to allow for vfd losses. I'll contact Newton Tesla ASAP but on hospital visit tomorrow (not me, SWMBO)
                                                The print in the manual is too small to photograph, but the same inverter does both single phase and 3 phase input. Either connect 200V 3 phase to R, S, T, or 200-230V 1 phase to R & S, T left not connected. The motor is connected to U, V, W.
                                                I've also checked the continuity of the motor coils, I get the same resistance (77 ohm) across any 2 out of 3 connections, which suggests no coils burned out.
                                                #539936
                                                duncan webster 1
                                                  @duncanwebster1
                                                  Found the reason for the lack of power, the primary drive belt was slipping. Should have checked that first, but it's not that easy to see the motor pulley, which is where it was slipping. What it needs is a flinger to keep the oil from the countershaft bearings away from the drive pulley. Another job on the to-do list.
                                                  Newton Tesla tried to help as usual, but he couldn't diagnose that one.
