Sieg C6 / SC6 Spindle Nose and Arc Euro Trade Chucks
Home Forums Manual machine tools Sieg C6 / SC6 Spindle Nose and Arc Euro Trade Chucks
  • #402142
    Brian G
      @briang
      My son wants to buy one of the self-centring 4-jaw 125mm chucks from Arc and as his new Chester uses the same mounting system (A rotating collar and 3 plug bolts) he wondered if he could use (or adapt) the Arc Backplate?
      The Chester has a 50mm spindle nose and three 20mm holes on a 75mm P.C.D. Does anybody know if the C6/SC6 dimensions are the same?
      Brian
      #13468
      Brian G
        @briang
        Will they fit Chester DB10 Super?
        #402165
          Hi Brian
          I suggest you contact Arc direct, I'm sure Ketan or ian will be able to check for you.
          Brian G
            @briang
            Thanks Neil
            I asked this morning but they don't have the information. Unless anybody with a C6 reads this he will have to make his own backplate.
            Brian
            EDIT:  Even without a positive result, getting a same-day reply from a supplier has to count as good service.
            Edited By Brian G on 26/03/2019 15:52:16
            #402860
            Brian G
              @briang
              Just in case anybody finds this in a search sometime, the two are not the same as the Sieg has a larger spindle nose, but I was able to fit a Sieg SC6 backplate to a Chester DB10 Super by making a cast iron sleeve to fit inside the backplate.
              Lathe Sieg SC6 Chester DB10 Super (2019)
              Spindle nose 52mm 50mm
              Plug bolt PCD 75mm 75mm
              Plug bolt hole dia. 20mm 20mm
              Brian
