Harrison Lathe Lubricants
Home Forums Manual machine tools Harrison Lathe Lubricants
  • #11944
    TobaccoBurner
      @tobaccoburner
      #92471
      TobaccoBurner
        @tobaccoburner
        Can anyone tell me which lubricants were originally specified by Harrison for the 13 inch L5 – This one.
        #92491
        Jon
          @jon
          Is there not a diagram either inside the covers or inside the opening door?
          For most things a hydraulic oil is acceptable whether standard or AWS (anti wear)
          For the head stock gears ATF the red stuff i can recall being recommended. After some checking for you Tractor fluid is ATF and in turn a mix of hydraulic oil.
          I used ATF in my scrapped 140 head and so does a mate with dare i say it the 11". Mine didn leak, a rarity.
          Gearbox a bit sketchy but dont get EP. An hydraulic oil of H68 or AWS68 is acceptable.
          General oiling hydraulic 32 or AWS32, there is no pace on any Harrison that uses grease, its all oil. A grease gun topped up with H32 fine for squirting in the nipples throughout.
          #92522
          TobaccoBurner
            @tobaccoburner
            Thanks for the reply Jon – useful info.
            Never thought of looking inside. I will do so next visit.
            The machine is only used intermittantly for maintenance jobs on our two big pumping engines (here if of interest) so servicing tends to be a bit neglected. Good job it was produced in the days when things were made to last.
            #92529
            Neil Greenaway
              @neilgreenaway71611
              Hi There,
              I have a 9" L5 and the specified oils were all old grade names – a local supplier narrowed it down to Shell Tellus 68 which is an ISO 68 grade hydraulic oil – local engineering or motor supplies hsould be able to supply a similar oil.
              Jon
                @jon
                Neil that is hydraulic T68 but can get now the AWS32 and 68.
                On my earlier Harrison something like this http://www.smithandallan.com/prodpage.aspx?id=1839 for the head and general oiling of slides etc, its also cheap at £13 plus postage for 5Ltrs.
                This is a bit thick unless only for the Norton gearbox http://www.smithandallan.com/prodpage.aspx?id=1840 Or just get the T68 hydraulic which will be similar viscosity to ATF D2. Wouldnt put this on the slides though, you can feel the drag, H32 ideal in that respect.
                #92766
                TobaccoBurner
                  @tobaccoburner
                  Latest update
                  Found a label Jon – not inside where you suggested but on the back of the headstock facing the wall – very convenient!
                  Sent in thin, agile, apprentice to read it and this is what he found:-
                                                       Mobil               Shell              BP                   Esso
                  Headstock
                  Feed Gearbox           Vactra Heavy      Vitrea 41     Energol HP30         Esstic 65
                  Slideways
                  Nipples
                  Motor Grease Cups   UX Grease 3       Alvania 3    Energrease LS3      Beacon 3
                  The only one I can find a spec for is Vactra Heavy:-
                  Mobil Vactra Heavy – Typical Properties
                  ISO Viscosity Grade                               100
                  Viscosity, ASTM D 445
                  cSt @ 40ºC                                            100
                  cSt @ 100ºC                                          11.1
                  Viscosity Index, ASTM D 2270                98
                  Pour Point, ºC, ASTM D 97                   -15
                  Flash Point, ºC, ASTM D 92                   246
                  Density @15 ºC kg/l, ASTM D 4052       0.89
                  Rust protection, ASTM D665:
                  Distilled Water                                        Pass
                  Pass                                                       Pass
                  Water separability, ASTM D 1401,Min. to 3 ml emulsion @ 54ºC    25
                  Next step is to have a chat with the nice man that supplies our oil and see what he has available.
                  Edited By TobaccoBurner on 19/06/2012 02:25:07
                  Edited By TobaccoBurner on 19/06/2012 02:31:25
                  Edited By TobaccoBurner on 19/06/2012 02:32:39
                  Edited By TobaccoBurner on 19/06/2012 02:33:03
                  Edited By TobaccoBurner on 19/06/2012 02:33:57
                  Edited By TobaccoBurner on 19/06/2012 02:34:47
                  #92767
                  TobaccoBurner
                    @tobaccoburner
                    Question – why did this dumb website remove all the extra spaces in my previous post and render the info in the two tables unreadable??
                    PS. Have found out that I can put them back by editing the uploaded post. However, as the layout in the edit window is different to that displayed on the site this is a time consuming trial and error process. B***** stupid.
                    Edited By TobaccoBurner on 19/06/2012 02:22:52
                    Edited By TobaccoBurner on 19/06/2012 02:41:37
                    #92770
                    David Clark 13
                      @davidclark13
                      Hi TB
                      Send the table direct to me as a Word document.
                      I will see what I can do.
                      regards David
                      Edited By David Clark 1 on 19/06/2012 08:34:42
                      #92820
                      TobaccoBurner
                        @tobaccoburner
                        Thanks David but not necessary. Multiple edits seem to have solved the problem.
                        FYI the original tables were copied from text files from MS Notepad, formatted using space characters. On upload strings containing multiple spaces were collapsed to a single character. The post editing function allowed the extra spaces to be re-inserted but the different formatting of the edit box and the uploaded text made this a trial and error process. Maybe one is using a fixed width font and the other a variable?
