myford super 7
myford super 7
Home Forums Beginners questions myford super 7
  • #661640
    Stephen Gill
      @stephengill79322
      hi i have noticed a small lever in the left hand side gear train area can any one tell me what's its for and how it should be set ?
      #11579
      Stephen Gill
        @stephengill79322
        lever identification
        #661646
        peak4
          @peak4
          Is it a lever, or a sliding bolt, which acts as a spindle lock?
          A photo, or a part number from the manual, or Myford's web site would help no end.
          Bill
          #661653
          Martin Kyte
            @martinkyte99762
            It’s a spindle lock to be used once you have broken the back gear cluster.
            regards Martin
            #661662
            Sam Stones
              @samstones42903
              Stephen,
              As I recall from my time on a Super 7 in the late 50's, it disengages the spindle lock before engaging the back gear.
              No doubt you'll get an update shortly. cheeky
              Enjoy your Myford. I only wish I was younger and had access to one.
              Cheers,
              Sam smile d
              #661672
              Sam Stones
                @samstones42903
                Stephen,
                I should have said …
                "Disengage (the lever) BEFORE engaging the back gear."
                Cheers,
                Samcrying
                #661726
                  I think that Martin means "Disengaged" rather than "broken"
                  Engaging back Gear and having the pulley / Bull wheel fixed to the spindle will lock up everything.
                  Some folk use this method so that a chuck can be unscrewed, but risk damaging the gears.
                  Hence the Spindle Lock to avoid such brutal practices.
                  If a particlar lathe uses screw on chucks but lacks a Spindle Lock, there are less risky ways of unscrewing a firmly stuck chuck.
                  #661776
                  Chris Crew
                    @chriscrew66644
                    I think you would have to be a very strong man to strip the back gear when removing a chuck. Probably could sheer the locking pin too!
                    Edited By Chris Crew on 27/09/2023 18:29:41
                    #661799
                    Stephen Gill
                      @stephengill79322
                      hi, thanks for all the answers it is so appreciated will be doing my first ever project the weekend tow pin for garden tractor . really looking forward to it. regards steve
