Knurling wheels misterry
Home Forums Beginners questions Knurling wheels misterry
Viewing 25 posts - 1 through 25 (of 36 total)
  • #640300
    Sonic Escape
      @sonicescape38234
      I bought one of these knurling tools that seems to be everywhere. They came with three sets of wheels. When I merged together the wheels with the largest teeth I noticed that they only partially overlap. Then I counted them and one wheel has 33 teeth and the other 34! Is this normal? What can be the purpose?
      #11449
      Sonic Escape
        @sonicescape38234
        #640303
        Macolm
          @macolm
          Possibly a "hunting tooth" to average out variations, so avoiding patterning?
          #640379
          bernard towers
            @bernardtowers37738
            That sounds like a bin job!
            #640389
            Tony Pratt 1
              @tonypratt1
              China (or India), strikes again, get a refund.
              Tony
              #640392
              Roderick Jenkins
                @roderickjenkins93242
                Does it matter? What does the pattern look like?
                Rod
                #640402
                Baz
                  @baz89810
                  Posted by Sonic Escape on 05/04/2023 21:17:51:
                  No it is not normal, wheels should have the same number of teeth or serrations.
                  #640406
                  Phil Whitley
                    @philwhitley94135
                    Try it, It may be perfectly good, it does sound like a hunting tooth, try it out and post up some pics.
                    Phil
                    #640411
                    bernard towers
                      @bernardtowers37738
                      I don't understand how you can have a hunting tooth on a knurling tool when the object is to have the wheels follow the same path every revolution or am I missing something?
                      #640413
                      Brian G
                        @briang
                        First question that comes to mind is whether the diameters are in the same 33/34 ratio?
                        Brian G
                        #640421
                          Posted by bernard towers on 06/04/2023 19:17:15:
                          I’m with you there, Bernard yes
                          … eagerly awaiting someone’s explanation..
                          #640426
                            Odd, but are the two wheels the same diameter? If so, they should have the same number of teeth to give the same pitch.
                            A possible explanation. Noting that it's the pitch that's important, not the number of teeth, if one of the wheels is made slightly larger, an extra tooth could be added to maintain the same pitch. The advantage of having an extra tooth on one wheel is it would distribute wear by rolling one wheel slower than the other.
                            Fulmen
                              @fulmen
                              I don't buy the hunting tooth theory, the two wheels aren't connected in any way.
                              My guess would be that they got two batches of cheap wheels and just mixed them together. If they're the same pitch the knurl should turn out the same. If they're the same diameter the knurl would be slightly asymmetric but I doubt it's noticeable.
                              #640436
                              DiogenesII
                                @diogenesii
                                33/34.. ?..for creating metric knurls on Imperial stock..? devil
                                #640437
                                Macolm
                                  @macolm
                                  Once there is an impression of the knurl on the work, it becomes exactly like three gear wheels running together. They stay in mesh. The advantage of a hunting tooth is that the effects of irregularities and wear will be averaged. The wheels would, of course, be constant pitch so slightly different diameters. If so, this may be a superior knurling tool!
                                  #640439
                                    Posted by Macolm on 06/04/2023 22:18:01:
                                    I’m happy to be wrong, but this statement from the opening post suggests wheels of the same diameter, but with different tooth counts: “When I merged together the wheels with the largest teeth I noticed that they only partially overlap.”
                                    Sonic Escape
                                      @sonicescape38234
                                      The wheels have exactly the same diameter, 25.83mm. I can't try them very soon because I have to fix better the tool post for this kind of operation. Here there is a better picture where you can see how the teeth start to be misaligned from the bottom:
                                      This is how I noticed in the first place that they have a different number of teeth. Besides that the wheels are identical
                                      Edited By Sonic Escape on 07/04/2023 07:47:05
                                      #640451
                                      Sonic Escape
                                        @sonicescape38234
                                        For the 1mm pitch wheels is the same story. 69 and 70 teeth. So maybe there is a reason for this. Apparently knurling is still hiding some secrets smiley
                                        It is strange that they don't have a marking to separate them.
                                        Edited By Sonic Escape on 07/04/2023 07:59:02
                                        #640452
                                          Thanks for the clarification yes
                                          I remain bewildered as to how that arrangement could be useful
                                          … but we’re all here to learn.
                                          Martin Kyte
                                            @martinkyte99762
                                            Why does it matter?
                                            Each wheel has only to register in the imprint it made on the previous revolution. Even the rivet counters are never going to notice that the rhombus pattern is not perfectly dimensioned across the sides.
                                            regards Martin
                                            #640458
                                            John Haine
                                              @johnhaine32865
                                              Try rolling them across a softish flat surface while fitted in the tool. Soft wood, plasticine? See what kind of pattern they imprint.
                                              #640460
                                                You’re right, of course, Martin … which presumably kills the ‘hunting tooth’ proposition.
                                                My own curiosity concerns around how that arrangement could be useful, rather than whether it’s good enough.
                                                Sonic Escape
                                                  @sonicescape38234
                                                  Posted by John Haine on 07/04/2023 08:35:15:
                                                  The pattern is ok
                                                  #640466
                                                  Martin Kyte
                                                    @martinkyte99762
                                                    I suspect the variation in pitch is down to the method of manufacture. If the knurls have bee made by knurling themselves then they could quite easily have a pitch error. If you look at the crests on the knurls they don’t suggest they were cut but formed which would raise the surface as metal was displaced.
                                                    regards Martin
                                                    PS This would make the pitch discrepancy an artefact of the manufacturing process rather than any intentional or useful design.
                                                    Edited By Martin Kyte on 07/04/2023 09:57:50
                                                    Edited By Martin Kyte on 07/04/2023 10:00:59
                                                    #640470
                                                    Phil Whitley
                                                      @philwhitley94135
                                                      As I suspected there is nothing wrong with them!wink
                                                      Phil
