Suggestions for lathe-only projects?
Home Forums Beginners questions Suggestions for lathe-only projects?
Viewing 25 posts - 1 through 25 (of 81 total)
  • #10552
    William Ayerst
      @williamayerst55662
      #509870
      William Ayerst
        @williamayerst55662
        Good evening gents,
        I've finished my first project on my ML7 – a machinist hammer. However, the projects I want to tackle next all seem to require a drill press or vertical slide for drilling and milling – and I own neither.
        Having just spent the wide end of £1500 I'm reluctant to spend another £200-400 on a Myford vertical slide and vise, and another £80-200 on a bench drill (and I wonder if that might better be put towards a mill or shaper).
        What I am after, is a purposeful project I can build to increase my familiarity with the tool – which isn't just another tool or pointless exercise – but I'm drawing a complete blank! My first question is – is there a handy list of projects one can build with JUST the ML7 without a vertical slide? I feel like a crazy person because there's got to be something!
        Any help or suggestion would be good – an imminent house move means that buying any more big machinery is off the cards!
        #509874
        Jeff Dayman
          @jeffdayman43397
          Pin punches
          hole punches
          rivet sets
          filing buttons
          toolmaker's buttons
          washer dies
          screwdrivers (filed ends for slot and Philips)
          machinist jacks w hex bodies
          vise stop for mill vise
          tailstock die holder
          wobblers
          spring loaded tap guide
          depth gauge
          boring bars
          many model parts – just pick a model and make the round bits
          Get the L H Sparey lathe operating book – he has plenty more ideas.
          #509883
          Steviegtr
            @steviegtr
            All the above are just another tool.
            I see where you are coming from. I am not the person to advise you. It seems like you would like a project to actually build something. Get ready for a stack of replies from members who have made many projects without anything more than a standard lathe.
            You could look out for a cheap pillar drill though. They are not all expensive items. My own is only a cheap Aldi item & does drill holes in a fashion. Anything accurate i do with the milling machine or in the lathe if it is roundish.
            Good luck with whatever you decide on.
            Steve.
            #509884
              I don't recommend a Milling Slide because they are seriously limited. Short travel, tiny workspace, bendy, and all round third-rate compared with a Milling Machine.
              Do you have a face-plate? Many milling and drilling jobs can be done on a lathe by clamping work imaginatively to the plate. A 3-jaw chuck can only spin symmetric work. A 4 jaw is more flexible in that jobs can be offset somewhat, but a faceplate has lots of room. Work can be positioned off-centre &/or at an angle. Obviously slower and less convenient than a drill or mill, but still useful. Faceplates were much used in the good old days before milling machines and pillar drills made us lazy!
              Interestingly, if a really accurately positioned and sized hole is needed, a faceplate is probably the best way to do it – see Toollmaker's Buttons.
              Sparey is well worth having!
              Double headed pennies are fun. Make a stub-mandrel and learn about super-glue!
                It used to be normal practice to use the lathe for drilling with a pad in the talistock, sometimes the pad has a vee groove for centering round things. Also prop things up and hold them in the toolpost – great for drilling a precision line of holes. Hold items in the 4-jaw or on the faceplate to drill aswell. Some holes only need starting in the lathe for precise position then can be finnished by hand drill (often better than a heavy electric battery drill).
                You have all you need to make a steam engine and boiler complete with safety valves and sight glass.
                If you can find an old enough mains Black and Decker drill from the seventies people are throwing the stands away after failing to sell them on ebay. They still drill straighter than by hand.
                #509891
                Paul Lousick
                  @paullousick59116
                  Hi William,
                  There are a 1000 and 1 projects to make on a lathe. It depends on what your interests and hobbies are. Do a search on Google and Youtube for ideas.
                  Harold Hall's website for metalworking has many projects; **LINK**
                  There have been lots of projects that have been machined on a faceplate and with a milling slide on a lathe but as mentioned above, they are limited in what you can make. A mill/drill is much more useful.
                  Paul.
                  #509897
                  Mick B1
                    @mickb1
                    Well, I wanna disagree with SOD about milling slides. I got mine in 2000 with a Myford Speed 10 – I think it cost me about £125 and another £25 for a vice that turned out to be pretty good.
                    Back when I was machining for pay in the 70s, I did quite a bit of milling on Bridgeports and a big Varnamo, so I'm reasonably familiar with the process, and I found that, even on the Myford 10, but far more so on the Warco WM250V that I've got now, I can generally do the milling and drilling I need in the lathe. My plan to buy a mill keeps getting put back – not so much for financial reasons as the disruption to other work it would cause. I think just about all the machined stuff in my album (except the hex-milling on railway stuff) was done in my lathe, and the vertical slide is mounted about half the time.
                    It's been hugely worth the money.
                    #509898
                    DMB
                      @dmb
                      Bazyle,
                      Some my earliest tool purchases many years ago included a B n D drill and stand. Stand was rubbish, column bent and it wouldn't drill 3/16" black mild steel. Drills were new as well. Resorted to hand operated Union bench drill, success! Still have both cluttering up the place.
                      William,
                      Are you intending a steam loco project? If so, why not obtain drawings and make a start, taking particular types of parts, e.g., boiler fittings as a smaller sub – project? Just the mechanical lubricated will be a nice challenge to start with! Whatever you decide upon, I wish you good luck. Do put up photos of your work for us all to see.
                      Be aware that a mill is very nice to have but cost doesn't stop there; you will need a number of endmills which are more than a tad more expensive than lathe or shaper tools. Either a machine vise or at least one angle plate will be needed. The list of accessories and tools go on and on and could cost quite a lot extra to the basic mill. Certainly don't want to put you off but will need some thinking about.
                      Edited By DMB on 25/11/2020 22:55:10
                      #509899
                      Clive Hartland
                        @clivehartland94829
                        A useful item for Xmas would be a Nut Cracker made from bar stock. It needs a thread, and all parts can be done in the lathe
                        #509900
                        Roderick Jenkins
                          @roderickjenkins93242
                          The Stuart 10V is can be made using only lathe. The steam ports are cast in to the cylinder. Edgar Westbury's "Building A Steam Engine From Castings" describes the various methods to manage without milling.
                          HTH,
                          Rod
                          #509901
                            You will need an independent 4 jaw chuck to make square or rectangular items with the lathe. Then you are away with lots of options.
                            #509902
                            Nick Wheeler
                              @nickwheeler
                              Posted by Steviegtr on 25/11/2020 22:07:24:
                              More importantly, most of them are sized to specific jobs – pin punches, filing buttons, hole punches etc – and are probably best made when you need them. Make one of each so you know how and move on. Otherwise, you burn through material and end up with lots tools that never get used. Like the machinist jacks I made when I first got the mill 15 years ago. I've never used them, and have recently converted one into a tool height gauge when my digital one died.
                              My suggestion would be to look around the house/car/bike/garden and see what you can improve or repair. Handles and knobs are a good bet; you could quickly develop your own house style.
                              Edited By Nicholas Wheeler 1 on 25/11/2020 23:01:20
                              #509904
                              DMB
                                @dmb
                                In my younger days and lack of knowledge and experience, followed Martin Evans' advice on using an endmill in the 3jaw to mill work on the vertical slide. (Not the current Editor of the same name. What's the chances of two editors of the same mag having the same names?) Well anyway, 3jaws useless at holding endmills, they just wind out of the chuck and cause a smash up. Vertical slide not rigid enough for serious work. Forget it.
                                #509910
                                Ady1
                                  @ady1
                                  screwcutting
                                  taper turning, internal and external
                                  live centre
                                  live centre with interchangeable inserts
                                  Edited By Ady1 on 26/11/2020 01:36:16
                                  #509912
                                  peak4
                                    @peak4
                                    I'm not suggesting this particular one, a two speed would be better (just as an example) but maybe a restore a hand operated drill press.
                                    New bushes, pinions, thrust washers, etc to make, and you end up with something useful as well; for little money if you purchase carefully.
                                    Don't decry them, I still use mine, normally set up with a countersink bit for de-burring holes, or the frame for tapping.
                                    Also make up an extra arm, swivel the drill head out of the way and the extra arm guides a vertical round bar with a drill chuck on the end to use with a tap for getting your threaded holes square; a bit like one of the kit staking tools.
                                    Yes I appreciate it's another tool, but it's also a project, and they drill holes quite well too. smiley
                                    Bill
                                    Edited By peak4 on 26/11/2020 02:28:21
                                    Edited By peak4 on 26/11/2020 02:31:11
                                    #509913
                                    Henry Artist
                                      @henryartist43508
                                      If you want some good projects where the end product is not a workshop tool or tool accessory I would strongly urge you to read the following books –
                                      • Building Simple Model Steam Engines by Tubal Cain
                                      • Building Simple Model Steam Engines (Book 2) by Tubal Cain
                                      • Making Simple Model Steam Engines by Stan Bray
                                      The first book on the list will probably be the most beneficial to you in the long run. In the first chapter – Ways And Means – the author discusses how the projects in the book may be completed by those with limited workshop facilities. Throughout the book alternative approaches to each step are offered. It's a great book for increasing your knowledge and skills. And you end up with a working steam engine!
                                      Since you have yet to acquire a drill press you may like to try a technique that has been known to Unimat (and Sieg C0) owners for many years – drill chuck goes on the lathe spindle and faceplate goes on the tailstock. Mount a small drilling vice to the faceplate or clamp the work directly to it. Ta-dah! You now have a horizontal drilling machine. face 1
                                      #509920
                                      David George 1
                                        @davidgeorge1
                                        Hi William have a look on here http://www.steves-workshop.co.uk/steammodels/simpleoscil/simpleoscil.htm
                                        I have made it satisfying when it works.
                                        David
                                        #509926
                                        Buffer
                                          @buffer
                                          What about a cannon. You can also turn the wheel hubs, axles etc and there is no need at all for any milling.
                                          #510171
                                          William Ayerst
                                            @williamayerst55662
                                            Hi guys, thank you all for the advice.
                                            One tool I definitely DO need soon is a sprung tap follower, so thanks Jeff, I’ve started to build one now. For the other subjects:
                                            Making things
                                            Ultimately I'm looking to build a live steam loco so could definitely look at building lathe-only compatible parts for that, it's a really good shout.
                                            Henry, I've bought that book as suggested, just to see what I can do.
                                            Buffer, I built a cannon on my Unimat which is what drove me to realise how much I ejnoyed the lathe! I have notional plans to build a carronade, so that's a good point…
                                            David and Paul, thank you – I will review those links.
                                            Buying a Mill
                                            DMB, and Mick – I'm just not in a position in my life right now where I can afford another 2-3k on a mill and accessories. Certainly at some point in my life I am, just not right now – and I don’t want to stop making things in the meantime.
                                            4-Jaw, Faceplate and Manual Drill Press
                                            Bazyle, SillyOldDuffer – I have a face plate and a 4-jaw chuck. I’ve not heard of using pads on the tailstock and drills in the chuck as an option. Do you have any examples or links to what it might look like? Peak4’s suggestion of a manual pillar drill might be a good compliment, maybe? I’m happy to size up drills rather than going straight for a 5/8” but just to be clear, I’m going to be able to drill brass, bronze, copper, iron and mild steel by hand? Restoring a vintage hand drill definitely feels like an awesome little project.
                                            Edited By William Ayerst on 27/11/2020 13:14:55
                                            #510204
                                              Posted by William Ayerst on 27/11/2020 12:03:47:
                                              https://www.myford.co.uk/acatalog/DRILL-PAD–PLAIN–WITH-HOLLOW-CENTRE-2125.html
                                              They are [or were] also available with a useful vee-groove
                                              peak4
                                                @peak4
                                                Posted by Michael Gilligan on 27/11/2020 14:05:39:
                                                In finest Blue Peter fashion; here's one I prepared earlier.
                                                I bought it from an exhibition or autojumble years ago; I looks all home made from solid bar stock on an integral MT2 taper.
                                                If I was going to make one myself, I'd use a separate arbor, to save time and metal, but make the head much larger to accommodate a bigger workpiece. ¾" is about the limit on this one.
                                                The photo was just a quick lash-up to illustrate the item for this thread, but the workpiece is actually genuine(ish).
                                                Lathe is a Warco 720 (Myford Super 7B copy from the '70s)
                                                It was the old piston for my trolley jack, which was scored and had damaged the seal.
                                                I made a new one, now fitted and working, out of some EN8 and drilled the cross hole using this jig.
                                                Bill
                                                #510222
                                                IanT
                                                  @iant
                                                  Well, if you want a project William – buy a blank MT2 arbor (>£5) and find some scrap steel plate (or an old backplate casting) and attach it to the arbor. You will save yourself £22 and can add tapped holes to take clamps etc. But think about it's practical use first.
                                                  Smaller items that you can 'swing' – can often be done in your 3/4 jaw or on the faceplate. Problems arise when you need to drill a hole in one end of something that's over about 90mm long – because it will stick-out and foul the bed. The tailstock pad avoids this issue but can be unwieldy (it has a relatively small 'clamping' area) for large items.
                                                  If you are thinking of getting a vertical slide eventually – then I'd put this £27 towards it. It won't be quite as convenient for one-off drillings as the tailstock pad but it will be vastly more versatile.
                                                  IanT
                                                  Edited By IanT on 27/11/2020 15:14:19
                                                  #510223
                                                  William Ayerst
                                                    @williamayerst55662
                                                    Interesting stuff! I guess buying the drill pad from Myford isn't a complete loss because I'll end up with an MT2 arbor to mount something like the above to, potentially?
                                                    I've seen a few hand drill presses with 2-speeds that look like they might fit the part. Just to be clear, those vertical drill presses are going to be good for things where absolute positioning is already worked out via punch marks – so no good for drilling two holes that are X" apart from first principles, but perfectly fine to drill those holes if they're already marked? I'm also assuming there's approximately zero percent chance of a slot drill working in those unless I'm just shaving the very smallest amount out of the bottom of a hole? Basically – just want to be sure that I'm not about to spend a bunch of time and cash restoring something that ends up being used all of once!
                                                    #510230
                                                    IanT
                                                      @iant
                                                      The drill stands are OK for smaller holes William (where great precision isn't really needed) and one will generally be easier to manage than a tailstock pad. The stand/drill combination won't handle slot drills – the drill will be too fast and the stand not man enough.
                                                      But you already have a lathe and that can be your 'precision' drill when required – or provide a much more rigid set-up than a drill stand can ever do. Here is my favourite 'V' angle-block being set-up on the cross-slide.
                                                      Here I've just used a 10mm (ish?) slot drill to cut a hole in a pair of frames for a small Sentinel engine I built a while back. Note the use of the Clarkson collet chuck (I do use an ER32 one too) to hold the slot drill and also the aluminium sacrificial plate behind the work. The plates were superglued together for this job and marked out for drilling. The holes were simply positioned by lining up the punch marks with a centre in the headstock. The work was then moved and re-clamped. Absolute precision was not required – provided the two sets of holes aligned with each other (which being both sets being drilled at the same time) – they did.
                                                      I will admit this was my second attempt – I used a 10mm drill the first time around and it snatched (thin material) and moved the work, resulting in an oblong hole. The slot drill solved this on the second attempt.
                                                      IanT
                                                      Edited By IanT on 27/11/2020 16:27:22
