Hi, I have a XYZ AT4 vfd working on my mill at lower speeds on either winding and its fine. But on the 2 pole motor and the two highest speeds it blows the mains 240v 10amp fuse. So I guess the higher torque is causing an excess inrush current to blow the fuse. The derating on the drive is OK, but I guess the 10amp is probably marginal but not had this on other vfds I have installed in the workshop.
I need to check the current with a camp meter but thought I would try to find if I can set the right parameter to at least limit any startup current. I'm looking at p24- overload protection buffer time, p34 -main rising velocity and p66-input stabilization time. Has anyone any advice on the best parameter to change?
Thanks
Barry
