I have Phonak in-ear speaker hearing aids for both ears which boost my top end spectrum. I was issued with a neck loop inductive coupler for these which is Bluetooth connected to a base transmitter. The base was connected to the TV line audio output set to my comfort level. This reduced domestic strife when the audio from the TV speakers was incompatible with our joint enjoyment levels.
I was impressed by the performance of the in ear devices as these are not isolated to the ambient sounds and I could hold a conversation while listening to the TV audio. There was also a large mute button on the neck loop receiver to completely kill the incoming audio feed (the 'Mcintyre Mute'
. The range of the Bluetooth is sufficient to allow for bathroom runs mid program while still keeping up with the program audio.
I was sufficiently impressed that I bought a second base unit and neck loop for the workshop. In the workshop I have an audio source switching box that allows either TV, radio (FM and DAB) or IPOD audio to be routed to the base unit. I can go about normal workshop activity without losing audio from the base and without losing hearing of ambient sounds. If I have a very noisy activity, my normal industrial ear defenders slip over the top of the in ear devices. And yes I wear the neck loop inside my shirt and my overall against my skin with my safety boots, wearing safety glasses, hi viz jacket, wash my hands before eating biscuits and drinking tea etc etc.
That aside and prior to the above being necessary, I used the same audio source switching box feeding a Band II low power modulator to give local radio coverage in the workshop. The signal was received on a freebee low sensitivity single channel Band II receiver with foam ear buds obtained at a golf tournament for on course commentary. This allowed simultaneous ambient and program listening. And yes I wore this inside my shirt and my overall etc etc etc.
Unless you happen to be of the fairer sex you will no doubt have been forcefully, at some point or other, made aware that as a male we are incapable of multi-tasking. Given the source of this revelation it must be true so it is perhaps pointless to listen to something while doing something else that demands thoughtful attention (including the source of the revelation …). If however you are trying to stave off dementia by undertaking learning something such as a foreign language it is surprising how much you absorb as background audio tuition while destroying metal (while wearing your overalls, safety boots, safety glasses etc etc).
Alan
