Again thanks Jason – I'll read them when I've a little more time. SWMBO wants some jobs done before it gets dark
Frances – The WM180 manual says that left hand threads are not possible. That is certainly true for an unmodified lathe.
However I reasoned that if I used a lathe tool upside down and ran the lathe in reverse I might succeed – I didn't by the way – all I got for my troubles was a metallic version of a bottle brush as it didn't cut at all cleanly.
I shall have to investigate making a new banjo arm to add an extra gear. Then I can cut a new cross-slide screw. Then I can mount a VMS and I can mill the item I set out to make in the first place.
regards
Bernard
