Winding springs on a lathe
Home › Forums › Beginners questions › Winding springs on a lathe
  • #705851
    Peter Simpson 3
      @petersimpson3
      I need to wind a few springs
      Using 0.41 mm wire. The OD is approx. 4.6 mm. Is there a calculation for the mandrel diameter to achieve the correct size spring ?
      #705857
      Andy Stopford
        @andystopford50521
        I should just go with trial and error – the spring will expand diameter-wise when the winding tension comes off it.
        #705859
        Fulmen
          @fulmen
          #705919
          Bo’sun
            @bosun58570
            Good morning Peter,
            If you have a copy, I’m led to believe there are charts/calculations for winding springs in “Machinery’s Handbook”.
            #705933
            ChrisLH
              @chrislh
              I wound 3 diffreent springs using the formulae in Fulmen’s reference. Each came out surprisingly close to its target diameter.
              #705963
              bernard towers
                @bernardtowers37738
                Model Engine Builder No 19 has a winder in it which I have. made and works well, allowing you to do close coils and vary the main pitch as well. Dersigned originally for model valve springs and allowing you to repeat so sets can be made.
                #705996
                Mark Rand
                  @markrand96270
                  I’ve got a job where I need to coil a bendable heating element to be a firm fit around some stainless steel pipe. Fulmen’s calculator site seems to say that I should be aiming at about 1.5″ mandrel diameter to match the 2″ pipe.
                  I’ll happily use that value in the hope that it comes out about right.
                  #706033
                  Paul Mills 4
                    @paulmills4
                    Mark
                    If you look at Fulmens link there is a factor k used in the calculation, which not only seems to vary with material but also varies as to how that value is calculated so I would be very wary about the value for mandrel diameter calculated, it may take a couple of attempts to get the correct value, hopefully the heating element could be uncoiled and rewound if it comes out wrong. Having said that if you aim for a slightly  smaller coil diameter then possibly it would be a firmer fit when on the stainless pipe.
                    #706041
                    Mark Rand
                      @markrand96270
                      On Paul Mills 4 Said: Having said that if you aim for a slightly  smaller coil diameter then possibly it would be a firmer fit when on the stainless pipe.
                      That was my hope 🙂
                      #706146
                      ChrisLH
                        @chrislh
                        Paul,
                        That’s odd.
                        I used both the formulae and the “calculate” button in Fulmen’s reference and got exactly the same answer for mandrel diameter for each material as you would expect. What did you find ?
                        #706213
                        Paul Mills 4
                          @paulmills4
                          Put in a couple of random sizes, and got same value for music wire and stainless as expected ( same formula for calculation of value for wire diameter coefficient ) and a slightly different value for  phosphor bronze wire.Again as expected.
                          Oddly the first attempt i used a coil diameter of 3 and a wire diameter of 0.026 gave a mandrel diameter of -1.38  for music wire so I suspect the original work may have had limits, perhaps to the ratio of coil diameter to wire diameter, although as I have not read the original article that is merely speculation.
                          #706214
                            On Fulmen Said:
                            There’s this one: https://daycounter.com/Calculators/Springs/
                            I’m late to the party, but thanks for that link
                            Good to see an online calculator that clearly states its working, and credits the the source.
                            https://craftsmanshipmuseum.com/artisan/kozo-hiraoka/
                            P.S. __ for the practicalities of making small extension-springs
                            https://www.homemodelenginemachinist.com/threads/springs-and-things.7552/
                            #706244
                            ChrisLH
                              @chrislh
                              Paul,
                              The usual recommendation is that the spring index (D/d) should lie in the range 3 to 10. However one of my springs worked out at an index of 28 and that was successfully wound on a mandrel calculated using the formula. Your random sizes give an index of 115 which is way outside the recommended range for mechanically satisfactory springs (drunken, unstable coils, etc.) and evidently outside the range considered by the originator of the subject formulae.
