I ordered the Warco DH-1 over the phone and the delivery was very quick indeed.
Sadly the quality of the DH-1 Vice itself is very disappointing. When I unpacked it there was evidence of the ‘hammered effect’ paint flaking off. Close inspection revealed a lot of debris and paint flake in the main-screw mechanism, paint flaking off having not adhered properly and some evidence of rusting under the painted surface. This surface is to be painted could not have been properly prepared, degreased, surface keyed and an etch primer applied to ensure proper bonding. Frankly quite why this item is painted at all is a mystery, surely it would be better for it to be ground all round and left as clear metal – like the Precision Tool Vices and 10mm Precision Universal Vice from ARC Euro?
I spent a good 1½ hours cleaning up the DH-1 vice, removing debris from the screw mechanism and removing flaking paint and oiling it ready for use. When I bolted it down to the mill table I noticed paint oozing out from under the hold-down points, so removed it and cleared away the paint from there too.
I then mounted the vice and carefully set-up the inside facing edge of the left end jaw clocked true along the Y axis. I then checked the other faces and unfortunatly they are well out of the stated tollerance- one of them by over 10 times the error! I have emailed the details to Warco last Monday – but have had no response yet.
