Which MEW had acme thread and tap article?
Home Forums Workshop Tools and Tooling Which MEW had acme thread and tap article?
  • #104226
    PekkaNF
      @pekkanf
      Hello,
      Can't find an artcle where writer was making acme/trapezoidal srew and made a tap (to make nuts) on the same go. It is the making of the tap that mystifies me most. Not having a TCG and all.
      I'm pretty sure I saw this article some time ago when I was looking something else, but can't find it on HH index or on my pile of MEW mags.
      Found only this on HH index (not what I was looking for!):
      171   48   LATHE WORK A BEGINNERS COURSE6   SQUARE AND ACME THREADS          M   BRYMER
      My long term project is to make a cross slide and considering buying normal RH 12 – 16 mm OD, 3 – 4 mm lead trapetzoidal screw and nuts to go, but I'm also looking for an alternative ways to make some.
      I need LH for a cross slide (if I go there…..) and RH for a compound. I just got thinkking that if I have 2.5mm lead on cross slide, 4mm lead on top slide might feel funny and make thimbles pretty big.
      Help opinions greatly appreciated.
      Thanks,
      Pekka
      Edited By PekkaNF on 20/11/2012 14:18:56
      PekkaNF
        @pekkanf
        Looking for a 14*2 mm lead screw and nut or a way to make it
        #104228
        dcosta
          @dcosta
          Hello Pekka!
          Using MEW_Index free application  ***LINK***  applying the word “thread” as criterion for the title field, I find 50 articles. If I use the criterion “acme” in the keywords field I find 2 articles.
          I think the article you are looking for is one of these two.
          Year: 2002; Issue: 82; Author: Loader; Title: Screw Threads are not just for Fastening; Keywords: Square threads Acme Buttress Multi start
          Year: 2010; Issue: 171; Author: Brymer; Title: Lathework, A Beginners' Course Part 6; Keywords: Square Acme and Multiple Start Threads
          In case you are interested in the 50 other articles, please send me a personal male and I'll send the list to you.
          Alternatively I can post only the issue number for the 50 articles.
          Best regards
          Dias Costa
          Edited By dcosta on 20/11/2012 14:27:38
          #104229
          PekkaNF
            @pekkanf
            Thank you,
            But it was neither! If my memery serves right the article was not about threading, but it had instructions how to make trapezoidal thread tap and I think it was sort of lead screw application. Damn! I should have bookmarkked or write it down or printa page or something!
            I'll be checkking the indexes and try to fing it out.
            Pekka
            #104272
            PekkaNF
              @pekkanf
              Found it! I went on reading top slide designs and found it just by pure chance.
              182 28 A new topslide with high-resolution angular readout (2)
              Actually that is 3rd instalment of that series. It had details on one method to make fluted acme tap, but it needs Quorn or such….I think I'll pass it for now and look alternative ways.
              Pekka
              #104307
              Brian Wood
                @brianwood45127
                Tracy Tools sell ACME form taps and dies, could save you a lot of work
                #104319
                Sub Mandrel
                  @submandrel
                  From memory I think it was an article about making a left-hand ACME thread and nut for a scale GWR screw reverser.
                  If not, I think Wile E. Coyote may be able to help you find a supplier.
                  Sub Mandrel
                    @submandrel
                    PekkaNF
                      @pekkanf
                      Posted by Stub Mandrel on 21/11/2012 21:03:03:
                      Nothing else but haples charcter chasing running avians comes into my mind. And ACME-brand rocket apparatus.
                      Is "GWR screw reverser." some loco-stuff?
                      Chekked Tracy Tools and ACME taps looks affordable, definately something to keep in mind, but metric one (trapezoidal) didn't seem to readily available "TRAPEZOIDAL TAPS – PLEASE TELEPHONE FOR AVAILABILITY"
                      Probably will buy a insert and tool-holder or try to make one ground HSS-variety with adjustable lead angle (left/righ) for outside thread, but under 16mm tap would be nice.
                      Thanks, Pekka
                      #104389
                      Sub Mandrel
                        @submandrel
                        Sorry,
                        a GWR screw reverser is indded a valve-reverser for a steam locomotive which uses a left-hand acme thread.
