wheels
wheels
Home Forums Beginners questions wheels
  • #125577
    david simmo
      @davidsimmo
      hi the hole in the wheel is to big(ebay) which is best drill and fit bushes brass or cast any help would be appreciated thank dave
      #6803
      david simmo
        @davidsimmo
        axel size
        #125580
        Nicholas Farr
          @nicholasfarr14254
          Hi David, assuming they are cast iron wheels and if they were mine, I would open them out a enough to get a reasonable piece of cast iron to give a signifcant wall thickness when you have the right size hole in it. I would also use Loctite 638 for retaining the bush in the wheel.
          Regards Nick.
          #125596
          Ian S C
            @iansc
            Use a cast iron bush if the wheel is free on the axel, if it is to be fixed tight , use a steel bush, and either way, do as above and use loctite. Ian S C
            #128961
            Boiler Bri
              @boilerbri
              I have a book by Martin Evans- The model steam locomotive. For me its a bible as i have no experience in building loco's. The loco in my avatar, i bought and rebuilt.
              I usually draw anything that i am going to make in 3d to check things are going to fit. I drew the axles and a wheel up for 5" as described in his book as i want to build a riding trolley to run behind the loco in my avatar.
              The 'land' for the wheel to sit on is 11/16" long and 11/16" diameter.
              The wheel is 11/16" bore and 0.535" wide – i think?
              When drawn up, the axles stick out of the wheels. So my question is: Are the wheels for standard loco's in 5" guage all different widths or are they all 11/16" wide?
              #128995
              david simmo
                @davidsimmo
                hi thanks lads all fixed now thanks dave
                #129092
                Sub Mandrel
                  @submandrel
                  Hi Bri,
                  Tubal Cain gives 0.535" as the standard width for 5" gauge in his handbook. In practice I understand the back to back dimension is the most critical, then the flange width.
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Hi ,
                    On full size engines details of dimensions of wheels varied all over the place in the early days .
                    Later on the back to back dimension was standardised for British engines at 4 ft 5-5/8 in .
                    Tyre width though continued to vary from company to company – anything from 5 in to 5-3/4 in on proper railways and almost anything on industrial ones .
                    Thickness of wheel hub , amount of inset / stand out of hub centre and actual details of axle ends varied from railway to railway and era to era .
                    Proper railways had flanges nominally 1-1/8 in thick by 1-5/8 in deep but with a complex taper plus curves profile .
                    Wheel treads were coned slightly primarily to reduce lateral hunting when running at speed and to some extent to ease travel around curves .
                    There never really was a completely standard set of dimension for wheels in full size and therefore no reason to have one on models .
                    Regards ,
                    MikeW
                    #129141
                    Boiler Bri
                      @boilerbri
                      Ok thanks for the replies. I have to assume the axle drawings are incorrect at11/16 land length or the extra is an allowance for machining off back to the face of the wheel.
