What’s best glue for joining wood to PVC pipe?
Home Forums General Questions What’s best glue for joining wood to PVC pipe?
  • #481274
    Simon Robinson 4
      @simonrobinson4
      Hi
      What glue would you recommend for joining wood to PVC pipe? Also what is the best primer to paint on the PVC so the paint does not scratch off?
      Also can I use epoxy resin to smooth the join between the PVC pipe and wood?
      Edited By Simon Robinson 4 on 21/06/2020 14:47:00
      Simon Robinson 4
        @simonrobinson4
        #481277
        Bo’sun
          @bosun58570
          Hi Simon,
          I'm no expert, but here goes. Roughen the PVC pipe to get a key, and try some polyurethane glue. A little experimentation would be prudent. As for primer, my guess would be an etch primer. Epoxy will tend to find it's own level to some extent, so I'd be inclined to use a 2 part wood or car body filler, or maybe some form of caulk, depending on the intended purpose.
          #481280
          John Haine
            @johnhaine32865
            Gorilla Glue Clear seems to stick most things.
            #481301
            Martin Hamilton 1
              @martinhamilton1
              You want Devcon Plastic welder 2 part adhesive, this is an acrylite glue intended for plastics. It is also good on metal, wood, glassfiber etc. Hobby shops or Ebay for around £8 or £9.
              #481309
              Ady1
                @ady1
                I just use pinkgrip for everything
                #481316
                Steve Skelton 1
                  @steveskelton1
                  Simon, a little more info would (NPI) help. What are you trying to achieve, what wood, what shape PVC – rigid or plasticised, the type of bond, application?
                  Steve
