Hello
I need to bond styrene (HIPS) onto a fairly waxy looking solid polyethylene (PE).
Mechanical background:
I need to attach piece of styrene which is about 5mm x 10mm wide to longish piece of solid PE (about 1 ft long). I dont know whether it's HDPE or LDPE (and I'm not sure if it makes much difference in this case!)
Apparently one option would be to use CA (Cyano Acrylate glue) having first used a primer.
For example:
A) "LOCTITE PLASTICS BONDING SYSTEM" has been suggested
Which contains a special activator and claims to work on plastics including "polyethylene and polypropylene"
OR
B) Deluxe Materials
I was in touch with Deluxe Materials who suggested:
1) Tricky Stick ("surface primer"
and then:
2) Roket Rapid ("Highest quality cyanoacrylate"
I don't know which of the above is more likely to work.
From what I can see, epoxy glues seem unlikely to work on polyethylene at all!
Cement
Maybe there is something very clever one could roughening the surface with microscopic hole and then just use cement the styrene and squeeze together??
Either way I think I shall resort to some sort of metal pinning as well.
e.g. I am thinking I might
– screw a couple of small screws into the body of the polyethylene,
– chop their heads of and then
drill a couple of matching holes into the styrene and then
put some CA/superglue onto the stubs of the screws and then
– stick the stubs into the two holes in the styrene.
It's just that finding a way to the styrene to PE with glue would definitely help and will also be v useful to be able to do without resorting to screws etc every time!
Thanks
Edited By John Smith 47 on 09/11/2015 23:26:19
