What Did You Do Today 2025
Home Forums The Tea Room What Did You Do Today 2025
Viewing 23 posts - 201 through 223 (of 223 total)
  • #808135
    Dalboy
      @dalboy
      Got around to making the studs for a couple of chucks. I got fed up with moving one set to the ER32 chuck and as I needed to make a backplate for a 5c chuck which also needed a set of studs.
      All the studs and the partially machined backplate
      DSCF4350DSCF4349DSCF4351
      Holes being drilled and tapped ready for the next stage, except I managed to break the tap in one of the holes will try to remove it tomorrow I think I have a cobalt drill bit to see if I can get it out. If not I can always move the holes around a little still leaving room for the chuck mounting bolt holes
      DSCF4352
      bernard towers
        @bernardtowers37738
        Had a go at thread milling today on my S7, what a revelation!, virtually no load on the machine and tiny chips for swarf and full depth in one pass and you can stop the thread or let it run a circular groove, magic. Only problem is you need a motorised head for the tool post and a means of running the lathe SLOW my tacho gives up below 9 rpm so slower than that. also comm cutters for 55deg dont seem to be avail(a job for another day)IMG_3941
        #809921
          Nice results, Bernard
          Your motorised head for the tool post might make a good article for the magazine.
          [please forgive me if that’s already been done]
            Not heard the term “comm cutters” but 55deg threadmills are available though mosly full form.
            #809943
            bernard towers
              @bernardtowers37738
              Its commercial cutters Jason,yes they are available but at north of £100 a pop not for me.
              #809955
                I don’t know what tpi you are cutting but these are a fair bit less until you git to the chunky ones, I’ve used their metric ones
                #809964
                Durhambuilder
                  @durhambuilder
                  Yesterday I machined the Redwing cylinder bore and bearing housings, I  forgot to take any photos at the time so these below are ‘mock ups’ showing how it was done; I did not bother recreating the clamping!
                  the main casting was fixed to a steel plate of appropriate thickness to bring the estimated centre of the bore to the centre of the lathe. The actual height above the machined base is not critical, a 5/8 plate brought the height to within 0.015” of the drawing dimension so that would do. I made a between centres boring bar from an off cut of 1.125” round bar with a 0.325” bit of reground hss (ex broken centre drill) as the cutting bit. This was initially too large to pass through the casting so initial cuts were done with a conventional boring bar mounted direct in the four jaw chuck. After a couple of passes I couldn’t get anymore offset in the boring bar so had to remount it in a collet block to get the required cutting radius. The between centres bar was used for the final 10 thou in a couple of passes. Final bore was 1.248” to allow for honing. Turning the casting through 90 degrees allowed me to do the bearing housings and get the same centre height. These were drilled in stages up to 1/2” then a small boring bar was mounted in the four jaw to bring them a few thou under 5/8”, the final couple of thou being taken out with a sharp reamer. For all of these operations the casting/saddle was advanced by winding the tailstock barrel against the outer edges of the bearing to keep everything square. IMG_2742IMG_2743IMG_2745IMG_2744
                  #810140
                  bernard towers
                    @bernardtowers37738
                    Glad to see they are mock ups that looks like a screwcutting tool to me!!!
                    #810146
                      They can be used to bore, it’s only the pitch that makes the difference between a feedrate and a screw thread. Not much different to using the threading insert to cut a run out groove at the end of a blind thread.
                      #810181
                      Durhambuilder
                        @durhambuilder
                        Needs must! Yes I did bore it with a screw cutting tool, it was the only thing I had that would pass through the 1/2” drilled bore. I think I’ve used that particular tool more for small hole boring than screw cutting! With a very fine feed finish was excellent and at the end of the day it’s only the tip radius that differs, in effect I cut a 4000tpi thread in the bearing housings. I’ve  also used very small milling cutters for boring, just set one cutting edge up to cut.
                        #810532
                        Diogenes
                          @diogenes
                          Golden hours of quality family workshop time!
                          IMG_2711
                          #810567
                          Vic
                            @vic
                            I finally got round to making a new base for my grinder setup. Today was cutting some 6mm slots in the Trespa to give me some adjustment for the grinding table.
                            IMG_5037
                            #810577
                            bernard towers
                              @bernardtowers37738
                              Diogenes, They look really nice, a good quality finish that takes time.
                              #810600
                              Diogenes
                                @diogenes
                                Thanks Bernard – at some point over the last year it’s finally clicked that very small features get visually ‘lost in the noise’ if the finish is too rough.! ..the ‘finishing’ business doesn’t come naturally to me..
                                #812062
                                John Hinkley
                                  @johnhinkley26699
                                  While waiting for the delivery of an ER25/R8 collet chuck, I remembered that I’d got some R8 collets lurking in a drawer, so a quick measure up and an hour on Alibre Atom had the design of a collet holder done.  Expert to STEP file and print the two parts in ABS-Glass Fibre. A touch of superglue et voilà, finished.
                                  Collet holder
                                  Can’t decide whether to make a lid for it or not.
                                  Roderick Jenkins
                                    @roderickjenkins93242
                                    On John Hinkley Said:
                                    Collet holder
                                    In a drawer, No.  On a shelf, Yes
                                    Very nice and a good colour
                                    Rod
                                    #812080
                                    John Hinkley
                                      @johnhinkley26699
                                      Thanks, Rod,
                                      They’ll be in a drawer, so I’ll save my filament!
                                      Diogenes
                                        @diogenes
                                        Not sure that the photo flatters the capitals 😒 ..nothing a mandrel and graver won’t cure..
                                        IMG_2732
                                        #812261
                                        bernard towers
                                          @bernardtowers37738
                                          Now thats when your finish on the columns pays off!!
                                          #812285
                                            Coming along well, shame it is all likely to get painted
                                            Will you keep going up and do the cylinder next or drop back down for the bearing pedestals?
                                            #812306
                                            Diogenes
                                              @diogenes
                                              I’m still thinking over the best strategy for the cylinder, as I think it will be one of the more challenging bits of fabrication for me – so I’ll probably do the lower end first, ‘cos then I can keep moving forward whilst I think..
                                              #812317
                                              Diogenes
                                                @diogenes
                                                I see they’re going rusty even in the driest summer we’ve ever had..
                                                #812325
                                                  Sweaty fingers🖐
