What Did You Do Today 2019
Home Forums The Tea Room What Did You Do Today 2019
Viewing 25 posts - 426 through 450 (of 1,046 total)
  • #411015
    Colin Heseltine
      @colinheseltine48622
      Got up early and went to car boot near Lichfield. Found a guy selling vintage woodwork tools, no so interested in those but he had a toolbox with reamers and drills. Negotiated the 5 reamers, radius end mill, plain end mill, countebore, burr and ball nose cutter down to a £5. Looked at the taps but decided to ignore them.
      Wandered round other stalls saw nothing of interest so went back. Decided to pick all the taps and a new box of E clips, and couple of sized spacers. Got talking to him and he said he had a few micrometers. Well I've got most sizes but had a look anyway. He had one I do not have a VIN Tube Micrometer. So I grabbed it. Quick negotiation an £10 got me all the taps, e clips, tube micrometer, carbide drill and the spaces and small parallels for £10. Result.
      Picture below, well worth £15 I thought.
      Anonymous
        Posted by Neil Wyatt on 26/05/2019 12:31:45:
        Let's steer clear of getting political..
        I'm not sure if the matter under discussion is a comedy or a tragedy, but it sure ain't politics. smile
        #411022
        Harry Wilkes
          @harrywilkes58467
          If it's the one on Muckly Corner no wonder all the swag had gone wink
          H
          #411023
          Colin Heseltine
            Harry,
            No not the Muckley corner one, the Wood Farm one near Curborough. Now the guy knows someone is interested in engineering tools he says he will hopefully bring some more along. He wouldn't normally buy/sell this type of stuff.
            Is there normally engineering type tools at the Muckley Corner one?
            Colin
            #411024
            Harry Wilkes
              @harrywilkes58467
              Dont know that on Colin will have to check it out yes
              H
              #411026
              Nicholas Farr
                @nicholasfarr14254
                Hi Neil, thanks for the info, bet they sound good. I love a bit lot of base. I'll bet they are a bit punchier than my pair of Disco cabs with 2 X 12" Goodmans twin Axiom at 40W DIN music power per unit, which I have in my music room (lounge) driven by a Tecnics SU-3050 amp.
                Hi SOD, why stop at 11, and mine are connected with Maplins heavy speaker twin, no thrills attached wire and sound pretty fantastic with anything from Easy Listening to the Groundhogs Split album.
                Regards Nick.
                #411035
                bricky
                  @bricky
                  Machined to size a pinion blank and cut 12 teeth to fit a circular rack of 9" diameter and 6" long which I machined the other day.
                  Frank.
                  #411042
                    Posted by SillyOldDuffer on 26/05/2019 13:00:17:
                    Posted by Neil Wyatt on 26/05/2019 12:27:16:
                    Posted by Nicholas Farr on 26/05/2019 08:34:46:
                    Hi Neil, nice piece of kit. What size are the units in the combo and power rating?
                    Regards Nick.
                    Combo is the classic 4×10" but the original celestions have been replaced with Eminence Alpha 10As rated 100W each. The cab on top is 2×12" Mackenzies (not sure but probably 100W each).
                    That's the original Trace Elliot GP11 Mk V combo so it's an apparently feeble 150 watts, but they have a reputation for being very loud and I am sure it's as loud or louder than an 500W ashdown amp and head I played with recently.
                    Trace gave very conservative ratings and headroom is more important than RMS for bass. The power supply is easily sufficient to put around 400 watts into 4 ohms. Today that would probably mean an amp with a sticker saying "1000 watts"…
                    Edited By Neil Wyatt on 26/05/2019 12:30:30
                    This table from Hyperphysics lists the power outputs of various instruments and rates a large orchestra at under 70W. I'm always a bit surprised how weedy musical instruments are. Are big amplifiers only needed because loudspeaker efficiencies are so low, or is it because rock and roll sounds best with the Volume at 11?
                    Source
                    Power Output (watts)
                    Large orchestra
                    67
                    Bass drum
                    25
                    Snare drum
                    12
                    Cymbals
                    9.5
                    Trombone
                    6.4
                    Piano
                    0.44
                    Trumpet
                    0.31
                    Tuba
                    0.20
                    Double bass
                    0.16
                    Flute
                    0.055
                    French horn
                    0.053
                    Clarinet
                    0.050
                    As all true music fans know even the best amps and speakers are garbage unless connected with Industrial Gauge Oxygen Free Gold Plated Silver Litz Wire Tri-filar wound on a helical PTFE core, and then fitted with bespoke insulating jackets hand-knitted in special-mix Kevlar, Carbon Fibre, and Vucana by nubile maidens. Nothing is too much trouble for proper audio pleasure…
                    I remember reading a book as a teenager where the author recounted doing an A/B test with an orchestra, audience and a speaker and concluded about 10 watts was right, but with a very efficient horn speaker.
                    I think the answer is complex. The easiest answer is to go to a concert by a big rock band and then you will know why.
                    Worth bearing in mind that a rock band with a massive PA throwing out 6,700watts is only going to sound four times as loud as that orchestra…
                    In practice, a lot of it is about headroom; I use a compressor which has three useful effects: it limits the peaks, reducing potential for hearing damage, it raises the quiet bits so I don't need to be as loud (and most importantly it helps mask volume differences due to deficiencies in technique )
                    As for the green pen hifi brigade, I suggest an 'oxygen-free environment'…
                    Neil.
                    Edited By Neil Wyatt on 26/05/2019 17:46:33
                    #411044
                    Mike Poole
                      @mikepoole82104
                      Ted Nugent ( not for nothing known as loud man) made my ears ring for three days and walking away from Birmingham Odeon I felt like I had a pillow over each ear. A gig in America where Ted used a 167kW sound system got complaints from 15 miles away. PA speakers seem to be much more powerful these days and more compact, I suppose the design has become more scientific and they are more efficient. Funny how I have been to more gigs in recent times with poor sound than I used to in the 70s. You would think the Spice Girls could afford a decent sound engineer and PA system but I saw they were slammed for poor sound at their Irish gig a few days ago. Luckily I will not be finding out if their UK gigs improve.
                      #411049
                      Samsaranda
                        @samsaranda
                        A 167 kw sound system is unbelievable, I guarantee that those within range would have suffered permanent damage to their hearing, not always apparent at the time. I suffered exposure to gas turbine engine noise in the early 60’s without hearing protection and consequently have suffered a profound loss on my high frequency hearing, I jokingly say that it is only women’s voices that I have difficulty hearing, really winds up the wife, the reality is that even with high gain hearing aids I struggle in any social environment, the only place I feel on the same level as everyone else is when I am clay pigeon shooting because we all wear ear plugs so we are all equally handicapped. Noise is such a crippling environment, youngsters are totally unaware of the damage they do to themselves when they wind up the volume on their earphones.
                        Dave W
                        #411052
                          Posted by Samsaranda on 26/05/2019 18:26:53:
                          Dave W
                          I fear more ears have been damaged by headhones than rock concerts.
                          There's this famous PA:
                          About 55kW, but the intention was focused more on spound quality than sheer power.
                          en.wikipedia.org/wiki/Wall_of_Sound_(Grateful_Dead)
                          Mike Poole
                            @mikepoole82104
                            It seems Teds puny 167kW system was trumped by Iron Maidens 500kW system at the 1988 Monsters of Rock at Donington, I missed that one.
                            #411068
                            duncan webster 1
                              @duncanwebster1
                              ………, or is it because rock and roll sounds best with the Volume at 11?
                              Rock n Roll sounds best with the amp switched off! Interesting as an ex trombone player that I was the loudest musical instrument, you can't count drums, all you have to do is hit them
                              #411070
                              martin perman 1
                                @martinperman1
                                Not so much what I did today but what I did at the weekend and that was to travel to a Gloucestershire campsite on Friday with my Brother and spend the Saturday at the Prescott Speed Hill Climb track watching all types of vehicles try to be the fastest, we then spent another night at the camp site and came home today.
                                Martin P
                                #411094
                                Danny M2Z
                                  @dannym2z
                                  Let's steer clear of getting political…
                                  My sincere apologies for raising the subject Neil. It was intended to be a light hearted joke using a play on words.
                                  * Danny M *
                                  #411099
                                  Wout Moerman 1
                                    @woutmoerman1
                                    Source
                                    Large orchestra
                                    67
                                    Bass drum
                                    25
                                    Snare drum
                                    12
                                    Cymbals
                                    9.5
                                    Trombone
                                    6.4
                                    Piano
                                    0.44
                                    Trumpet
                                    0.31
                                    Tuba
                                    0.20
                                    Double bass
                                    0.16
                                    Flute
                                    0.055
                                    French horn
                                    0.053
                                    Clarinet
                                    0.050
                                    This is probably the power needed in the living room for reproduction of the music? For stage performance we need a bit more power to fill a hall satisfactory. But I'm always surprised what I can manage with my double bass unamplified. As long as I play indoors….
                                    #411100
                                    Anonymous
                                      You forgot to mention the gold plated mains plug…………….smile
                                      #411113
                                      Mike Poole
                                        @mikepoole82104
                                        The megadecibel sound systems of rock bands undoubtedly can inflict hearing damage on performers and engineers and you often see hearing protection being used. A full orchestra in all its glory is quite a fearsome spectacle, the sound created seems beyond the tiny figures listed and hearing damage is a concern for members of an orchestra and I believe hearing protection is used by some players especially some in the firing line of some of the more powerful instruments.
                                        #411115
                                        Circlip
                                          @circlip
                                          Wasn't the live verses recorded Gilbert Briggs demoing his latest (at the time) speakers? Worked for Leak/Wharfedale and on a sales team demo, saw how many in an audience picked the same speakers over the latest computer optimised some thirty years later. Having said that, most of the audience were "Sold" a pair of empty boxes on a later demo with various speakers covered with black cloths but having a light above them to show which were live at the time.
                                          One of the amusing pastimes at lunchtimes was reading the bovine excreta in the Hi-Fi comics by the "Exspurt" reviewers. Some could detect "Musicality" (something I can hear but you can't) in speakers that were neutral according to the 1,000,000 pound anechoic chamber we tested them in. When asked, I used to say, only thing to take note of when buying a "System" is a record(??0 you know and a pair of clean ears, buy what sounds good to you and spheroids to the critics. Your money, your choice.
                                          Oh yes, and LOUD is good. Think the most ear damage has been done with lugplugs and the volume turned up to drown normal conversation. Tried having a conversation in a pub/café lately? Even those on a table at the side of you SHOUT at each other.
                                          Regards Ian.
                                          #411120
                                          Nicholas Farr
                                            @nicholasfarr14254
                                            Hi, I went to see Wizzard once in our local Corn Hall, which is quite large. This was the loudest band that I ever experienced. I had to move to the back of the hall and it was still too load for me and I had to leave before the end of the performance because it was hurting my ears so much. Status Quo were also quite load but tolerable, they had a few stacks of WEM slave amps on their stage and numerous speakers.
                                            Regards Nick.
                                            #411169
                                            henryb
                                              @henryb
                                              I started cutting some spokes for the minnie, i think the angle grinder is going to have to come out to do the rough cuts its too much with a piercing saw. i need to find some tube for the wheels as well.
                                              #411185
                                              Boiler Bri
                                                @boilerbri
                                                I had a stress free – i did not take my loco – day at West Shore in Llandudno driving, being a guard and station master on a public running day with the clubs loco.
                                                Passengers were steady in numbers and the weather was mostly dry
                                                A great day out.
                                                Bri
                                                #411208
                                                AdrianR
                                                  @adrianr18614
                                                  Went to Carrington steam rally today, spent far too much on metal and tools, did get some good deals. A couple new of end mills and new reamers for £1, each but the real result were; Moore & Wright metric/whitworth thread gauge RRP £50 for £8
                                                  And a new dovetail cuter for £8
                                                  #411259
                                                  Nigel Watts
                                                    @nigelwatts49512
                                                    Followed some good advice received on this forum and ground a new HSS lathe tool to turn down slender arbors for a clock restoration project, then tried it out with very satisfying results.
                                                    #411325
                                                    Gary Wooding
                                                      @garywooding25363
                                                      My son spent the weekend with us and I spent the weekend teaching him how to use my mill. We made a replacement sustain block for his Ibanez Edge Pro guitar. The pot-metal original had stripped a couple of threads and I thought it would be a nice experience to make a replacement in brass. We had a good time together deciding setups and machining steps.
                                                      Edited By Gary Wooding on 28/05/2019 12:00:10
