Not today only but finished milling the 'steps' (recesses?) in the buffer bars for my Cracker build. This required me to knock up a quick carriage lock as the milling cutter kept dragging the carriage along and ruining the piece…
Once that was fitted I set about milling the ends of the bars. Please note, my workholding set-up is very rudimentary and the finish is not to a high standard but the parts have ended up far squarer and to-dimension than I could manage by hand.
Marked out and rouged out with a hacksaw (this one was actually a ruined piece but you get the idea)…
Then into the milling vice…
I have no idea if the 2-flute, 4mm cutter I used was right for the job. I tried to make sure the work was always fed 'at' the cutting flutes (climbing?) and used Tubal Cain's guide of 1/4 cutter diameter for 'plunge' depth and 1 diameter for maximum side cutting depth. Sometimes it 'felt' ok and sometimes it didn't. I settled on 2150 rpm. Cross-slide and vertical slide gibs are significantly tighter than when I started, as I kept tweaking them up a bit to keep it all moving in one plane only. So my fingers are a bit sore from turning the hand-wheels now.
Eventually, and after 2 scrappages, I ended up with two matching (well, very close, much better than I could have hoped to do by hand) buffer bars…
After that I couldn't resist a quick mock-up of the frames…
I've altered from the original design slightly. In the plan the buffers are only 10mm deep (instead of the 10X20 I used) and the frames are scalloped (?) to half depth for roughly their first and last third. I wanted to simplify the marking and cutting of the frames, and I think the end look will have a more British industrial NG vibe about it. Possibly.
Next will be drilling the frames, wheels/bushes/axles/gears(bought I'm afraid…), then I'll make a start on the oscillating motor. For those who don't know the model, it has a single, single-acting oscillating cylinder, mounded vertically on one side with a flywheel on the other.
I start my passenger hauling 2-10 Austerity next week…. Yeah in my dreams
