Ah at last got my hands dirty still bitter cold outside. A quick trip into the garage grabbed my Vernier, Micrometers, hex keys and Dremel a shifter.
Job No1
Oldest son asked on Saturday night to repair a Nail Puller
Some fellow at work had taken to the plunger tip with a grinder made a real mess of it.
Quoted cost of replacement almost as much as original unit. A few searches brought up the links and for about $60+ it can be replaced.
Alternative plan is
1 re-grind the tip correctly which will shorten it by 5m then turn down the shroud to suit
2 Make a a whole new plunger section if I can undo the two parts. Tried today but not able to.
Job No2
My Dremel an old one some 15 years or more gave a shudder bad vibration and bounced about in my hand and cut out last week.
Its been dropped a few times not had a hard life really but done a fair bit of work.
I figured bearings and/or brushes ere due for a change
Opened it up gave a clean, checked brushes all ok, bearings ok, then spotted two loose wires going into rotor area. Now its never been apart before tightened them up re-fitted everything and is sweet once again.
