What Cutter / Method ??
Home Forums Beginners questions What Cutter / Method ??
  • #6738
    chris j
      @chrisj
      #121454
      chris j
        @chrisj
        Starting with a 3" Diameter round steel bar
        I want to end up with several pieces about 1" thick with something like a 1/2" shallow (2" wide) in the end of each piece, like an ashtray (does that make sense ?)
        So I figure, I set the bar in the chuck square and true and cut the 1/2" deep scallop out of the end face, then use a parting tool to take a 1" slice off the end, job done.
        So what method would you employ to cut the scallop out, I can't seem to settle on something comfortable. If I drill a hole in the centre 1/2 deep I can then get a boring type cutter in there and open it up. The pain is I have to use two cutters to do the scallop and a third to part.
        What do the panel thing is the easiest method/cutter type. ?
        #121459
        Chris Heapy
          @chrisheapy71135
          Yes, use a stout boring tool. Be wary of parting off dead to the length required, a facing cut will probably be needed if surface finish is important. I have a 1" 2MT shank endmill which I plunge-cut start a recess like that, then I can use a larger diameter boring tool. However, 3" dia is too big for me to part off comfortably, I would tend to saw the blanks off first and work from there.
          #121467
          Ady1
            @ady1
            Drill the hole from the tailstock
            Once you've drilled the hole even an ordinary pointy left hand carbide tool will be sufficient for the 1/2" recess
            bear in mind that you are cutting loads more material on the outer edge than the centre, and you have less torque, so cut more slowly on the outer part
            edit: And practice with a few  "finishing cuts" before you reach full depth and width and have to do the real deal
            Edited By Ady1 on 04/06/2013 01:42:39
            #121469
            Ady1
              @ady1
              The other thing to bear in mind is parting off
              If you haven't done it before, as mentioned previously, you may be better sawing off 7 blanks and doing each one separately
              (On a production line they would put the 3" bar through the spindle bore of a big Herbert Turret lathe to keep everything close to the chuck kinda thing)
              #121558
              chris j
                @chrisj
                Thanks Guys
                I had a better day today, probably because I was heartened to think I was doing it about right.
                #121560
                nigel jones 5
                  @nigeljones5
                  I find that if all else fails, sacraficing a goat helps…..might only work for Myfords though?
                  #121612
                  chris j
                    @chrisj
                    So I have opened the hole out nicely but the bottom is a bit messy.
                    What do the panel think might be the best tool to clean it up. ?
                    #121614
                    merlin
                      @merlin98989
                      Also bear in mind that there will be some distortion after removing such a large chunk from the middle so, assuming that it is important, allow a good few thou for final cleaning up of the two large faces.
                      #121669
                      Trevor Wright
                        @trevorwright62541
                        Chris,
                        The tool you bored out with will clean the bottom face nicely, just do 0.005" cuts till you are happy with the finish. Make sure you have the point of the tool on the centre-line or you will leave a pip if low and chip the tool if high.
                        I would not attempt to part off that thickness unless you have a pretty sturdy machine. Machine the front and recess, cut off on a saw, turn around in the lathe and face the back to the thickness needed.
                        Trevor
                        #121690
                        chris j
                          @chrisj
                          Thanks Trevor
                          I found a great video by Tubal Cain on youtube last night.
                          What he suggests is to push down the sides towards the chuck (increasing the diam of the hole) and when at the bottom, stop and move towards the centre cleaning the base. Obviously leaving a couple of thou to deepen the hole ready for this. I'm going to give that a try and see how I get on.
                          I have also secured a Warco 812g single phase bandsaw that I'm collecting tomorrow !!
