Warco wm18
Warco wm18
Home Forums General Questions Warco wm18
  • #403422
    Boiler Bri
      @boilerbri
      I have a wm18 milling machine. Recently the tooling has become difficult to free from the morse taper. It used to take a slight tap with a hammer to free the tooling. Now I am having to give it a bit more than I like to free the tooling. As I only really use a collet chuck and various drill chucks I am thinking of leaving the collet chuck in place and fitting a drill chuck with a parallel adaptor, thereby not needing to remove anything from the morse taper.
      Boiler Bri
        @boilerbri
        #403535
        mechman48
          @mechman48
          Hi Bri.
          I have the WM16; sounds like you are tightening the draw bar up fairly tightly. You only need to hand push the tapers together to fit, then I only snug up the draw bar max' 1/8 turn, if that, I then find it is easier to use the top hat to release the drawbar without having to resort to using the potential to kinetic energy converter.
          George.
          #403547
            Posted by Boiler Bri on 03/04/2019 21:29:39:
            Try checking for dirt or swarf on the male and female tapers. Hard to see inside the spindle, so give it a good clean with a toothbrush, or a brass brush. You might be able to feel particles stuck inside with a finger.  The problem may be dirt stopping the tapers from gripping properly, forcing you to overtighten the drawbar, and making the chuck hard to release.
            Edited By SillyOldDuffer on 04/04/2019 12:50:28
            #403553
            Journeyman
              @journeyman
              This would appear to be exactly the same topic/thread as this ***THREAD*** perhaps the moderators could concatenate them.
