Warco WM16
Warco WM16
Home › Forums › General Questions › Warco WM16
  • #117048
    Fred Nightingale 1
      @frednightingale1
      Has anyone fitted a vertical stop to a Warco WM16 or know if there are any drawings for such a modification
      Thanks in advance
      Fred
      #22582
      Fred Nightingale 1
        @frednightingale1
        #117789
        Bazyle
          @bazyle
          I guess they thought having the digital depth gauge was enough and you would just stop at a number. Warco web never gives you enough data to see if the digital depth thing can be zeroed or set to a value.
          Anyway you could consider a rotation stop on the main feed lever like on some drills. Limits you to 1 rev but possibly the easiest. It looks like there is too much casing around the quill to follow the common milldrill practice of a collar on the quill with an arm and so on.
