Warco VMC – Chester 626 Mill Dimensions Please extension
Home Forums Manual machine tools Warco VMC – Chester 626 Mill Dimensions Please extension
  • #12471
    Nick T
      @nickt
      Nick T
        @nickt
        Evening All,
        I am doing some workshop planning and would be grateful for the following dimensions for the VMC / 626 mills:
        (i) I need the overall depth and width of the mill including wheel handles.
        (ii) The mill will be going as close as possible to a wall on its left side, so what is the distance from the centre line of the mill to its maximum extension to the left, once again including wheel handles.
        Many thanks,
        Nick
        PS: Just noticed typo in title. Apologies.
        Edited By Nick T on 25/04/2015 19:37:55
        #187738
        Vic
          @vic
          Dimensions here:
          http://www.warco.co.uk/milling-machines/40-vmc-turret-mill—vertical-milling-machine.html
          Adding the traverse measurement will give you the working width.
          #187740
          Mike Clarke
            @mikeclarke87958
            Hi,
            I have limited room too and placed my mill at 45 degrees in the corner – which works quite well.
            #187745
            Nick T
              @nickt
              Thank you Vic & Mike for your help.
              I have looked at the Warco Website already but wanted to double check. The Chester 926 dimensions are totally different although its is the same machine.
              Just to confirm and using the Warco dimensions, the overall width would be 1092mm and the carriage would extend a further 370mm to the left?
              Sorry to sound pedantic but I will be buying the mill later and once the position is decided upon there is not much flexibility.
              Regards, NIck
              Edited By Nick T on 25/04/2015 21:02:42
              #187746
              MalcB
                @malcb52554
                You can gain an extra 3 or 4 inches if you make your LH table Handwheel redundant.
                Also allow at least an extra 4 inches on height as you will probably end up making a spacer to lift your Z axis range.
                #187750
                Mike Poole
                  @mikepoole82104
                  My Warco VMC needs 1500mm from handle end to handle end and wound to full extension left to right, the depth is as warco quote. I think with a little work on the table end bearing housing a bit more travel could be gained if you may one day need it.
                  #187752
                  Steven Vine
                    @stevenvine79904
                    Hi NIckT
                    I'm right on the verge of getting one as well, just need to organise a workshop to accomodate it. I also would like some confirmation of a couple of dimensions, so I can plan ahead as I'm going to mount it on a bench and not the stand. And I have to have it hard up against a wall to the left!
                    Can anyone give the dimensions of the cast base (not the steel stand) i.e depth front to back, and the width?
                    Also, can anyone tell me the distance between the bottom of the cast base and the top of the table, when the table is in the lower position.
                    Can I also ask, does the screw for the knee protrude below the cast base into the steel base at all? If so, by how much?
                    I'm hoping the maximum space required either side of center of base, as you look from the front, is 750 (looks like Mike has confirmed this, thanks also).
                    Sorry if I am intruding on your post., but would really appreciate these critical dimensions.
                    Steve
                    #187767
                    Oompa Lumpa
                      @oompalumpa34302
                      I placed my Mill adjacent to the doorway. On full right traverse it intrudes into the doorway space.
                      It works for me.
                      graham.
                      Nick_T – I have sent you a PM.
                      Edited By Oompa Lumpa on 26/04/2015 08:35:03
                      #187770
                      MalcB
                        @malcb52554
                        Steven Vine – if you are bench mounting then you will need to allow for a hole in the bench and clearance underneath for the knee screw to come down into. On my early 626 model the screw comes down into the cabinet quite a bit, on mines it's 6".
                        Edited By Malc Broadbent on 26/04/2015 09:11:08
                        #187775
                        Vic
                          @vic
                          Just had a measure.
                          Handle to handle on mine is 45 1/4"
                          With the table wound all the way to the left it measures 28 1/2" from the handle to the centre of the machine.
                          The Z screw protrudes 5" from the bottom of the cast base with the table down.
                          The distance from the top of the table to the bottom of the cast base is 17 1/4" with the table at the lowest point.
                          Hope this helps. It's a nice mill by the way!
                          #187776
                          Vic
                            @vic
                            Forgot. Total width required Left to Right (working envelope) is just under 60".
                            I've allowed 6" behind the motor for access etc although you could go closer and swing the head if required. This puts the Y handle on my machine 46 1/2" from the wall.
                            Total height required on mine to raise the belt cover and remove the draw bar is 77 3/4". Mine is the MT3 version for which I made a self extracting draw bar, not essential but it shuts the yanks up…
                            #187829
                            Nick T
                              @nickt
                              Thank you everyone for your help and advice, especially the correct measurements for the machine. My colleague suggested cutting out cardboard shapes to represent the shape of the items of equipment that are going in the workshop. I have had a very productive day shuffling the cardboard pieces around and have come up with what appears to be a perfect solution.
                              Once again thank you. Nick
                              #187836
                              Vic
                                @vic
                                No problem. My fixed machines are all located along the long side of my shed. Starting at the left I have the Mill, Drill then Lathe. I can work on long pieces on all machines if needed. I personally think it's a bad idea to put any machine at 45° in a corner as you can't work on long pieces but I know some do like this placement.
                                #187947
                                Steven Vine
                                  @stevenvine79904
                                  And thanks from me to Malc, Vic and everyone else for the dimensions and info. I much appreciate your time with the tape measure.
                                  Have you got the length and width of the cast base at its bottom where it sits on the stand, and also the approx measurement from the back wall to the front of the cast base. I trying to work out the depth of bench I need?
                                  Steve
                                  #187962
                                  Vic
                                    @vic
                                    The cast base is 16" wide and 22" front to back. With the motor just clearing the wall the back of the base would be about 8" away from the wall. Allowing for motor access and belt slipping etc your bench needs to be at least 32" – 34" I'd say Steve.
                                    #187999
                                    Steven Vine
                                      @stevenvine79904
                                      Hi Vic
                                      Fantastic, many thanks. That's exactly the info I was after. I had guestimated the depth to be around 27inches. Back to the drawing board yet again.
                                      Steve
                                      #190873
                                      Mark P.
                                        @markp
                                        Morning chaps, I have just ordered a Warco VMC, can anyone tell me how much headroom is needed to remove the draw bar please? I have 2020mm between floor and the ceiling in my workshop will this be enough?
                                        Regards Mark P.
                                        #190886
                                        Roger Vane
                                          @rogervane67137
                                          Hi Mark
                                          That should be fine. I've just measured my ceiling / floor dimension as around 25mm more than yours and my drawbar comes out OK, but I have a 100mm raising block fitted, so you should have no problems.
                                          If I remove the drawbar 'vertically' then I have 10mm or so to spare, but as the spindle bore is far greater than the drawbar diameter in practice you can tilt it as you remove it with lots of clearance. My guess is that you could also fit a 100mm raising block and still be able to remove the drawbar.
                                          Hope that this all makes sense, and that you enjoy your new machine.
                                          Good luck, Roger.
                                          #190887
                                          Nick T
                                            @nickt
                                            Just wanted to say thanks to everyone for their advice on this thread and that I bought a Tom Senior Vertical Light mill this morning. Lot of thought went into it but one reason was its 'relatively' small footprint compared to the VMC.
                                            Regards, Nick
                                            #190919
                                            Mark P.
                                              @markp
                                              Thank you for the info Roger, I was getting a bit worried that I would have to cut a hole in my roof!
                                              Regards Mark P.
                                              #190948
                                              Vic
                                                @vic
                                                Posted by Mark P. on 22/05/2015 09:52:22:
                                                Regards Mark P.
                                                I gave the minimum height required in post #11 (77 3/4&quot about a month ago…
                                                #190962
                                                Mike Bondarczuk
                                                  @mikebondarczuk27171
                                                  Hi Mark,
                                                  I have the Warco 626 version and a ceiling height of 2003mm and not encountered any problems with removing the draw bar, so your 2020mm should be ample.
                                                  Best regards,
                                                  #530385
                                                  Tibbsey
                                                    @tibbsey
                                                    Hi all, sorry to resurrect such an old thread, but I thought it made more sense to keep this kind of gold dust information together.
                                                    I too am trying to work out how to get a quart in a pint pot! The dimensions I'm interested in that I've not managed to find elsewhere are the clearance under the table at its lowest height (on the original stand) and the depth from the back of the throat to the wall.
                                                    The latter in particular looks quite large – just trying to work out if there are any potential overlaps to be had, which might make it a little less conspicuous!
                                                    Thanks
