Warco verses Chester lathes
Home Forums General Questions Warco verses Chester lathes
Viewing 25 posts - 1 through 25 (of 32 total)
  • #272819
    Scrumpy
      @scrumpy
      hi all I have 2 lathes a Harrison L5 and a Mitchell of Keithley ( very large ) 18 ins dia chuck and 10 ft bed but due to health reasons I'm unable to spend time in the cold workshop as my electrical supply will not run to heating if machines are in use but I have a spare bedroom in the new year I was going to purchase a small lathe size about 18 ins between centres and 4 in chuck with a weight of about 120 kg I have been looking at a Warco or Chester website but unable to decide which firm any advice would be appreciated Derek
      Scrumpy
        @scrumpy
        #272823
        Gray62
          @gray62
          I've had several machines including 3 lathes from Warco and all I can say is I have no complaints about quality or service. They are local to me so that also influences my choice of supplier. No affiliation, just a satisfied customer.
          #272825
          MW
            @mw27036
            Hi derek,
            My interest in this is as I have a warco machine. Forgive my ignorance but I was under the impression the machines were almost the same as each other bar a few changes here and there?
            Michael W
            #272831
            shaun hill
              @shaunhill88399
              Personally i would get your heating in your shed sorted out, ive got a harrison lathe and have also had several chester and warco smaller machines, still have got a chester coventry lathe, chalk and cheese compared to the harrison, dont get me wrong they turn ok, but cheaply made, rubbish motors and switches , and fasteners made of cheese, put them right and you have a ok machine, im not slating the warco, chester machines there good value, but not a patch on your harrison,unless of course its wore out.
              #272837
              MalcB
                @malcb52554
                I have equipment from both in my workshop and really like my Chester 626 VMC.
                I was on the brink of buying the Chester Crusader Deluxe ( almost put a  deposit at the Doncaster show ) when a not to be missed deal became available on my Harrison M300 which became a no brainer at the time.
                My choice of the Chester over the Warco equivelent earlier on in the year was based on two things:
                1. As daft as it sounds, the colour. I very much dislike the green they insist on using at Warco and if in fact I could live with it or have to repaint. To me ( and this is only opinion ) the Chester machines colour schemes look more modern and acceptable. But for looks the Amadeal machines would take the lead.
                2. As Graeme has mentioned i.e. location, Chester are about 45 mls away. Warco are about 4 x that distance away. It is more convenient if needed. I think that the Warco has a slight edge on build finish which they then spoil with the green.
                Good luck with your choice.
                Edited By MalcB on 19/12/2016 19:39:30
                #272838
                Scrumpy
                  @scrumpy
                  Many thanks for your advice the reason I'm unable to use heating and machines is my supply unable to cope I had a survey done by a sparks a new supply would have to be put in but with digging a trench 30 metres long to fit a cable and a new consumer unit and all the upheaval cost £1450 for 3 months use that's my thinking on Warco vChester to machine some small parts in winter
                  #272839
                  Carl Wilson 4
                    @carlwilson4
                    Run a big extension lead from your house to your workshop with a oil filled or similar heater.
                    There’s no need to put a Ford fiesta on your drive when you have a Rolls Royce and a Bentley in the garage.
                    #272840
                    Boiler Bri
                      @boilerbri
                      Hi. I have a Chester crusader deluxe, 2009 model, to sum it up I sold a 5" Boxford to buy it. I wish I had never bothered. There rubbish compared to old English made machines.
                      The handles drop off, the tailstock is not at the same height as the chuck spindle, the cross slide works it way backwards, the indents on the gear selectors are poor fitting and many times have I crashed the gears.
                      I could go on but I am waiting to unload my anger when the results of the trials come out in model engineer after they have taken place.
                      #272841
                      Scrumpy
                        @scrumpy
                        Hi no the Harrison is in good condition complete with dro as is the Mitchell although some 50 years old, when I was an apprentice my first job was to clean the Mitchell each day as it was brand new some 40 years later when the factory closed I purchased it a good buy at £400-00 as I had used it most weeks but at 3 ton plus I wondered had I done the correct thing in the 10 years I had it in my workshop it has been invaluable sorry I didn't now that the lathes were the same except colour
                        #272842
                        Bikepete
                          @bikepete
                          Any chance non electric heating might be worth a try? e.g. Wood burner with chimney? Or a gas fire which vents the exhaust to outside. Also if it can be really well insulated and draught proofed the heat requirement goes right down. Good luck either way.
                          #272862
                          MalcB
                            @malcb52554
                            Posted by Boiler Bri on 19/12/2016 19:47:51:
                            Wow, could have had a lucky escape then.
                            #272864
                            John Haine
                              @johnhaine32865
                              Unless you do your machining in the early hours, why not install an electric storage heater or two, which you could "charge" when you're not using the workshop? The power will also be cheaper if you have Economy 7.
                              #272871
                              Ian Skeldon 2
                                @ianskeldon2
                                Hi,
                                After veiwing and playing with both Warco and Chester lathes at the Warwick Model Engineering show I chose the Chester. Several of the Warco machines were rough on the cross slide and I am guessing that the spindles were either slightly bent or inorrectly assembled. Both machines are essentially the same with cosmetic differences to seperate the branding.
                                To date my lathe has been good and no problems to report, but it is early days.
                                #272873
                                mechman48
                                  @mechman48
                                  I have a Warco 25V-F lathe & a WM16 mill bought at the Harrogate exhib' in 2012; Initially they sent me the wrong lathe but that was resolved easily enough just had to wait a bit longer for the new stock to come in. From day one they both worked out of the box. I did have a few tweaks to do on the lathe but nothing that affected the running of it. I have blown the fuses a couple of times but that was purely down to me i.e. stopping then starting immediately again, but once I got used to allowing it to come to a complete stop then restarting all is fine.
                                  ​Colour is no bother too me but that is a personal choice whether 'tis blue, grey, green, it doesn't affect the operation of the machines & to date both machines have done what I've given them. You've got to remember that this size of machines are for 'hobby use' & not accepting of the types of d.o.c. that you ask a Harrison / Colchester etc to take, but as far as value for money goes you'd be hard put to match them.
                                  George.
                                  #272884
                                  Carl Wilson 4
                                    @carlwilson4
                                    Posted by John Haine on 19/12/2016 21:31:52:
                                    His issue is he can't afford the cabling, trench etc to get power in for the electric heating.
                                    I like the previous idea of a woodburner with a chimney. I know a guy near me who has a big shed in his garden that is his motorbike restoration workshop. He has made himself a woodburning stove to heat it, with a chimney.
                                    #272886
                                    John Stevenson 1
                                      @johnstevenson1
                                      Wood burners are Ace.
                                      I have quite a large shop and it's uninsulated. I had a problem years ago of getting a business up and running with as much space as I could build and as many machines as I could afford but little funds.
                                      The result was i built uninsulated with the idea to go back later and insulate but you never do.
                                      Fitted the big wood burner and now warm as toast as quite a few on here who have visited will confirm.
                                      Up side is no condensation with wood and no rust. I never cover or oil my machines and the beds and chucks are rust free all year but it does get daily use.
                                      Being in the heart of the chair frame making industry we have no problems getting seasoned beech wood.
                                      In fact one local company drop me two skips a week off, all I have to do is tip it and then either take the skip back or ring them to collect it.
                                      Middle of winter.
                                      Sometimes it CAN get a bit out of hand !!!!! wink
                                      #272892
                                      duncan webster 1
                                        @duncanwebster1
                                        Posted by Carl Wilson 4 on 19/12/2016 23:30:18:
                                        The point of a storage heater is that you heat it up before you go into the workshop, so you're not using the machines at the same time, so no extra load. There must be some kind of electricity to run the machines
                                        #272901
                                        Carl Wilson 4
                                          @carlwilson4
                                          Fair point.
                                          #272908
                                          Mark P.
                                            @markp
                                            I use storage heater in my garage worhshop, it’s on a timer and comes on for a couple of hours in the early morning.
                                            As for Warco or Chester I have used both and don’t think there’s not much to choose between them, I’ve had a Warco WM250 for some years and it does all I ask of it.
                                            Mark P.
                                            #272911
                                            John Haine
                                              @johnhaine32865
                                              Please read again. There is power for the machines.
                                              Anyway, why go underground? B&Q sell 25m of 27amp outdoor cable, armoured, for 25 squids. Run that along a strainer wire above head height. Must be cheaper than underground and certainly cheaper than a new lathe!
                                              #272914
                                              Scrumpy
                                                @scrumpy
                                                Hi All many thanks for all your help and suggestions the wood burner would be the answer but as I have a listed thatch cottage its a no no as my insurance would go up more than double ( could buy 4 lathes for the extra to pay ) the night storage looks to be the best option there is a 30 amp cable running to the workshop but part is split to a 30×15 greenhouse but the workshop supply could power a storage heater overnight that looks the way to go as both the Harrison and Mitchell lathes are a joy to use season greeting to you all
                                                #272917
                                                Nick_G
                                                  @nick_g
                                                  Posted by John Haine on 20/12/2016 09:22:00:
                                                  It's 1.5. It mat be 'rated' to 27 amps but actually do that over 25 mts and you would get a horrible case of VD.! surpriseblush
                                                  Nick wink
                                                  #272918
                                                  Ex contributor
                                                    @mgnbuk
                                                    Maybe not when you include the installation & certification costs, as supplies to outbuildings are Notifiable Work under Part P Building Regs and, depending on the cable length & load, the "27A" cable may not be adequate.
                                                    Nigel B
                                                    #272959
                                                    Martin 100
                                                      @martin100
                                                      Woodburners might be ok in the open country but they are increasingly choking up our villages, towns and cities. The clean burn type approved for smokeless zones might be ok but homebrew things are generally filthy. Maybe you don't care, but you should.
                                                      The B&Q '27 amp outdooor armoured cable' at 1.5mm2 will do about half that (14.5 A) or around 3.5kW at 25m with under 5% voltage drop.
                                                      Why does everyone and his dog seem so averse to lots of insulation and reducing heating requirements to the absolute minimum (or nothing) ?
                                                      Storage heaters force you into a regime where your daytime electricity costs for everything else are significantly higher, for the dubious 'reward' of lower cost heating you may not even require the following day. Even with 100% occupancy they are evil antiquated things, always have been, always will be.
                                                      With a suitable south facing wall a solar air heater can be knocked together by a complete amateur in a couple of weeks.
                                                      Have both a solar heater and significant levels of insulation and you'll never need a gas, electric, wood or coal fired heater, leaving more money for workshop machines
                                                      A few links on solar air heaters:
                                                      https://en.wikipedia.org/wiki/Solar_air_heat
                                                      http://www.builditsolar.com/Experimental/PopCanVsScreen/PopCanVsScreen.htm
                                                      http://www.motherearthnews.com/diy/build-an-inexpensive-solar-heating-system-zmaz77ndzgoe
