War o wm18
War o wm18
Home Forums General Questions War o wm18
Viewing 25 posts - 1 through 25 (of 36 total)
  • #26533
    Boiler Bri
      @boilerbri
      Boiler Bri
        @boilerbri
        I have a wm18 milling machine. Recently the tooling has become difficult to free from the morse taper. It used to take a slight tap with a hammer to free the tooling. Now I am having to give it a bit more than I like to free the tooling. As I only really use a collet chuck and various drill chucks I am thinking of leaving the collet chuck in place and fitting a drill chuck with a parallel adaptor, thereby not needing to remove anything from the morse taper.
        Does anyone know of a supplier of drill chucks with straight adaptors?
        Bri
        Edited By Boiler Bri on 03/04/2019 21:30:58
        #403424
        Pete.
          @pete-2
          YsAAOSw~WtbjRO-&frcectupt=true”>https://www.ebay.co.uk/itm/Straight-Shank-Drill-Chuck-Arbor-1-2-Dia-B16-Ref-41005036/372424420746?hash=item56b639ad8a:gYsAAOSw~WtbjRO-&frcectupt=true
          #403426
          Pete.
            @pete-2
            I just used B16 as all my chucks seem to be B16, I think Arc Euro also sells some obscure drilling adapters, I think they even had a female MT2 to straight shank for using MT2 drill bits in a cordless drill.
            #403482
            Yngvar F
              @yngvarf
              You can make the drawbar captive, then it releases with a couple of spanners instead of the big hammer.
              That said I made 20mm adapter for the boring head and made or bought one for a drill chuck.
              So the er32 chuck stays in 99% of the time.
              Ebay
              #403484
              Daniel
                @daniel
                How about this ?
                RDG Tools
                #403487
                Journeyman
                  @journeyman
                  Why bother with the drill chuck at all. I nearly always use the drill bit directly in my ER collets. Works for me, saves changing chucks and gives a bit more headroom. I don't know if it is an "approved" method but can't see any drawbacks.
                  AdrianR
                    @adrianr18614
                    The question I would ask is why are the tapers sticking?
                    Assuming the tools are the same temperature as the mill, a couple of reasons I can think of are. The tapers are getting rough/scored or the spindle bearing is getting too warm.
                    #403585
                    mechman48
                      @mechman48
                      Posted by AdrianR on 04/04/2019 10:51:22:
                      Dirt or grit in the tapers; clean out the tapers, see if you can feel any scores in the spindle taper, have a look at the tool taper to see if any indication of scoring, embedded grit on taper etc.
                      George.
                      #403602
                      Boiler Bri
                        @boilerbri
                        Thank you for the replies. Tapers are all in good condition and i always lubricate them at change
                        The adaptors will be fine
                        Cheers
                        #403615
                          Posted by Boiler Bri on 04/04/2019 17:49:44:
                          Cheers
                          Ooo, is lubricating the problem? I only wipe mine with a clean cloth. Don't know if that's right or not – it just seemed sensible not to lubricate a taper that's intended to not turn.
                          I wonder what the effect of oil in the taper is? My guess is the drawbar has to be pulled tighter than otherwise and then the oil tends to be squeezed out leaving a tight un-lubricated metal-to-metal bond.
                          What do others do and think?
                          Boiler Bri
                            @boilerbri
                            I only put a small amount of oil on and spread it around.
                            Been doing it a long time. Problem has only started recently
                            Bri
                            #403678
                            AdrianR
                              @adrianr18614
                              I was taught to not oil, just wipe clean with your hand.
                              If the problem has just started happening, then something must have changed. Have you bought new oil? Damage/dirt in the taper? Temperature changes; Are your tapers colder than the mill? Is the spindle bearing getting warm? Are your cutters blunt so you are using more pressure to cut?
                              Adrian
                              #403687
                              Chris Evans 6
                                @chrisevans6
                                Do you use a soluble or other cutting oil ? The steam from these when warm can tarnish the steel and leave a sticky but dry coating. I used to run a Colchester 2000 lathe where the slideways on the bed needed cleaning to prevent the saddle feeling tight after using coolant.
                                #403692
                                mechman48
                                  @mechman48
                                  New one on me; have never used oil on Morse tapers in all of my 55 yrs in the engineering industry, always checked tapers for burrs, embedded grit, scores, if all good then only wiped clean then pushed together. IIRC you can get a taper cleaner from ArcEuro / Chronos, usual disclaimer.
                                  George.
                                  #403698
                                  Boiler Bri
                                    @boilerbri
                                    The cold is a thought. With my engine nearing completion i have been using the miller in the cold which i rarely do sometimes never in the winter. So it may be ok as the weather improves.
                                    I will wait and see as my flurry of use is over at the moment
                                    The oil is only light oil which is used in oil baths and drip feeder etc Millers which is good quality
                                    Bri
                                    Edited By Boiler Bri on 05/04/2019 09:45:53
                                    #403704
                                      It may be that after long use slight wear has made the commonly used tapers an even better fit.
                                      Some form of elector system is the answer.
                                      mechman48
                                        @mechman48
                                        Here's a link for you to look at…
                                        There are also you tube videos on taper cleaning tools etc.
                                        George.
                                        Edited By mechman48 on 05/04/2019 10:20:06
                                        #403859
                                        Howard Lewis
                                          @howardlewis46836
                                          Not having a captive drawbar, I removed the nut (LH thread) retaining the pulley to the spindle. Turned back the under side, to form a register . Bolted a plate with two tapped holes further out, on opposite sides.
                                          Fit to machine so that the plate is seated on the register on the underside of the nut.
                                          Made up a plate with two clearance holes to match the spacing of the tapped holes, but with a central tapped hole.
                                          M6 should suffice, I used 1/4 BSF threads, in 3mm plate
                                          When it comes time to change the tool: Slacken drawbar by a turn or so, attach upper plate with two bolts, tighten central forcing screw. Taper usually separates, without need to thump the bearings on the quill. If it doesn't, a light tap on the tight forcing screw does the trick.
                                          #403983
                                          Boiler Bri
                                            @boilerbri
                                            I left the heater on last night all night instead of once every hour for quarter of an hour I think it helped being warmer.
                                            I will look up the taper cleaners
                                            Thanks for all the help
                                            Bri
                                            #403996
                                            Daniel
                                              @daniel
                                              Posted by Neil Wyatt on 05/04/2019 09:54:26:
                                              Uuumm ….
                                              At the risk of appearing daft, what is an elector system ?
                                              cheeky ATB
                                              #404002
                                              mechman48
                                                @mechman48
                                                Posted by Daniel on 07/04/2019 12:02:09:
                                                Uuumm ….
                                                cheeky ATB
                                                I think Neil meant 'ejector system'…devil
                                                George.
                                                #404008
                                                Boiler Bri
                                                  @boilerbri
                                                  Its the new avatar its gone to his head 😳
                                                  #413960
                                                  Boiler Bri
                                                    @boilerbri
                                                    OK so I forgot about this problem as the weather warmed up. I cleaned all the tapers i use on the milling machine and the bore itself. The problem seems to have gone away for now.
                                                    Trouble is it does not end there.
                                                    I was running at top speed milling some bronze the other evening and the speed counter stopped working. Before i start dismantling the think has anyone else experience this problem?
                                                    Is the speed calculated via the drive or is it a counter of some sorts on the spindle?
                                                    Bri
                                                    #413964
                                                    Daniel
                                                      @daniel
                                                      Hello Bri,
                                                      I had the same problem on my Weiss.
                                                      Look under the cover at the top of the spindle. There is a plate which runs through a sensor.
                                                      This became contaminated with grease. Gave it a clean, and it worked as it should.
                                                      I could send a photo in the morning, if that helps.
                                                      ATB,
                                                      Daniel
