In starting off, …a little background: The engine I am building is a large bore , low p.s.i., (40 p.s.i.) low r.p.m. grasshopper steam engine, .using dry steam but no superheat.
Regarding porting design, the inlet steam will be seperate from the exaust steam. I am using the pre existing D slide valve port surface as the base to build a type of spring tensioned swing valve that seats against the outgoing exaust pressure rather than seating inline with the exaust pressure. In this way it will do double duty as a water-slug relief valve..
In order to attain the most effective sealing against vacume loss and because steam temperatures will be well within the opperating limits, I am thinking of using metal backed viton rubber for the valve material. Anybody caring to take pot shots at that idea, opinions invited
