Thanks Maurice, Hopper and my fold made Mr Hanna,
Now it looks as if I am spoiled for choice! I like your method Maurice as making the necessary 2mt to expanding rod device is pretty easy to do and I can also use my Radford style tool for scribing the lines, it is good to have the 3 stops to give degrees, five degrees and 10 degrees different scribed lengths.
Hopper, your method will give me similar results for the cost of making up a detent system to fit on the lathe. So it all comes down to which of the two "adapters" do I want to make? the detent lever is probably simpler. However the 2mt taper and expanding tube will allow further adaptive use of the Myford dividing head.
Dallas, your method has got a lot of merit. If I can devise some variable saddle stops to do the different lengths, then I am home and dry. I do have the Myford 6 position stop, so I could use that (it came with the lathe and has never been used as yet).
Talk about spoiled for choice! I think I will make the dividing head adapter anyway as well as the detent system. I like making goodies for the lathe. I will give it a thought or two over a glass of Australian red this evening! Thanks everybody for so many helpful suggestions. I need to machine the circular T slot in the rotating Quorn body before I can finish off the degree scales so I will have time to mull it all over. I am now down to small doses of morphine, so I am probably OK to start machining safely, once more.
Thanks again everyone,
Andrew.
