A machine gets set up and tested on a test rig in a factory.
It may then travel half way around the world in a container, sit in storage for months or years, before being transported carefully to someone's workshop. It is then set up on a bench with no particular specification in uncontrolled temperature conditions.
If it is in perfect alignment and adjustment, that is more likely to be luck than quality production…
I suppose you may be correct, but I suspect it has a lot to due with the quality of the machine, and hence what it costs? Without trying to harp..My Emco 14D is by all counts a 'smallish' machine – It is the successor to the older Emco Super 11, so maybe in the Wabeco D6000, or between the Warco 1236 and 1230 models.
It was verified in the Emco factory before shipping to Namibia – a 2 month Sea journey, and then by road to me. An Emco rep was present for commissioning and performed the same verification as done at factory – NO noticeable change at all…37 measurements done..
I can post the Emco check sheets if anyone is interested, but the measurements are extensive – Runout on spindle internal, external and flat face ( all less than 0.0018mm!) Runout of test bar in chuck, including longitudinal runout from left to right ( ie, saddle moved from left to right with dial on bar) – less than 0.0022mm!, etc…They also measure the twist in the slide by attaching a DTI, and applying a set load on the slide, first at one end, then the other, and measure DTI deflection…
I realise that if you pay 50,000 or 80,000 Pounds for a machine , this level of return may be expected, but the 14D was WELL below that price – below 18,000 Pounds – which is 'only' 4 or so times the above mentioned Warco models.
I believe you get what you pay for in most cases..And I know one cannot compare a European made machine to one made in China, but by the same token, then,
It benefits from a little setting up but that's true of every lathe – anyone who thinks you can plonk a lathe down on a bench and expect it to give it's best without checking the gibs etc. is deluding themselves.
is really only applicable to a certain range of lathe or to a certain supply base, or maybe , more to the point, to a 'cheap' lathe as opposed to an inexpensive lathe..
Pedantic, I know, but…
I'll now do as that other fellow and get my coat..
Joe
