Wilkinsons/Wilko isn't the first place I'sd go to find innovative tooling, but I saw one today and popped in to see if they had the nut & bolt pick'n'mix Rik did so well at. They didn't.
They did have two adjustable spanners of a type I hadn't seen before, and that looks rather well designed, if not for shifting really tight fixings.
If it isn't clear in the pic, the moving element has a V-notch at each end. they also do a larger version, which I thought looked a bit lightly built for the sizes of hex it was for..
