Universal pillar tool question
Home Forums General Questions Universal pillar tool question
  • #23264
    Ken Weeks
      @kenweeks58536
      #150367
      Ken Weeks
        @kenweeks58536
        I have an bought an unfinished Universal pillar tool to complete.
        Most of the main work is done just needs handles etc. to complete.
        The base appears to be an earlier clamp type with a slot using a bolt to clamp the upright rather than later type using a draw in brass plug for the clamp.
        The book only shows the later type.
        What thread was used on the earlier clamp?
        Ken
        #150371
        NJH
          @njh
          I'm sorry to say Ken that, although I made a pillar tool, (many years ago!) the fixing was not the clamp type you describe. Even then I'm afraid I cheated and the column is fixed by a thumbscrew tapped into the side of the base. My only justification is that it is effective and has withstood the test of about 40 years of use! Thankfully GT did not see it !
          I'm hope that you too will find the tool useful.
          You may like to look HERE where there is another build of the tool and, who knows, a mail sent there may get an answer to your question
          Norman
          #150374
          Jo
            @jo
            GHT's original design of this tool shows the base using the slotted clamp on both versions but most people fit it with the draw clamp. The older book "Building the UPT" says 1/4" whit or BSF….which thread depended on what you had in stock.
            Jo
            #150380
            John Haine
              @johnhaine32865
              Or you could use M6…
              #150381
              Jo
                @jo
                Not if the casting is already threaded wink 2
                Jo
                #150406
                John Haine
                  @johnhaine32865
                  And was it? OP didn't say. If it is, easiest thing to do is take it to a decent fastener supplier and ask to try out the bolts you think it might be to find one that fits.
                  #150624
                  Ken Weeks
                    @kenweeks58536
                    Thanks for all the help.
                    It was already threaded and 1/4" Whitworth did the trick.
                    Ken
