Ok, here's an update…. Success!
I have now trammed in the mill, and have declared that a victory.
I had one of these Stainless handrail mounts lying around, which turned out to be very accurately machined, and it saved me the expense of buying a "circular square".
I mounted the "stainless handrail mount" on my rotary table, on the stage, and dialed that in with my DTI with respect to the stage. The column of the "stainless handrail mount" was then perpendicular to the stage.
Then I took the back cover off the mill, to allow a mag-clamp DTI holder to be attached to the moving part of the z-axis. This allowed me to assess whether the z-column was aligned to the column of the "stainless handrail mount", and tram it in using shims under three of the four M10 mounting bolts.
Then a DTI holder was mounted on the spindle, and used to check the spindle against the column of the "stainless handrail mount". The head was rotated until it was even, and a shim was fitted in the gap where the head rotates to raise the front-back angle of the head.
This completed the three-stages of tramming.
As a final check, the rotary stage was removed, and the DTI holder on the spindle was used to sweep a circle across the stage. This showed that the alignment was good to +/-10um (0.4 thou).
I have found that care must be used on this hobby-mill to keep this calibration valid. In particular I have found that depending which way the z-axis adjustment wheel was last turned will put enough bending force on the column to affect the front-back calibration. Also, doing up the the z-axis lock handle seems to affect it a bit too.
The machine lacks the basic rigidity to achieve any better, and it was as much as I could justify spending.
Still, I'm happy with the result, and it should be perfectly adequate for my purposes.
Thanks for all the helpful advice!
Nicholas Lee
