Tool steel suppliers UK
Home › Forums › Workshop Tools and Tooling › Tool steel suppliers UK
  • #571158
    Jon Harrison 3
      @jonharrison3
      I could do with locating a good UK supplier of 10x10x100mm or 125 mm HSS tool steel.
      I'm not sure about the far Eastern stuff if it's like everything else from there hence the question, and Ebay's very hit and miss unless it's branded stock.
      Recommendations appreciated
      My thanks.
      Edited By Jon Harrison 3 on 13/11/2021 17:20:09
      #20496
      Jon Harrison 3
        @jonharrison3
        #571162
        Howard Lewis
          @howardlewis46836
          Arc EuroTrade offer 10 x 10 x 100 toolbits in HSS-Co5.
          Reference is 080-060-40110 Catalogue 11 list at £5.09 ea + p&p,,but prices may well have increased since the catalogue was printed.
          Don't know the provenance, but would have no qualms whatsoever about dealing with Ketan.
          HTH
          #571166
          DiogenesII
            @diogenesii
            Here;
            Rennie Tool Co – M42 8% Cobalt..
            ..labour's a wee bit more expensive in this country.. £18.66 a stick.. ..only 4 left!
            Did find these tho' – worth a look for milling cutters;
            MR Tools – Special Offers
            Edited By DiogenesII on 13/11/2021 18:12:14
            #571170
              MSC do Eclipse blanks though I have a feeling they may only do imperial size eg 3/8 and probably about £20.
              The ARC ones that I have used seem to do what I ask of them
              #571199
              Ron Laden
                @ronladen17547
                All my tool steel I have bought from ARC both Cobalt and non Cobalt and its all been fine with no issues, also the pricing is good. I think the 10mm square may be out of stock though so you would need to check.
                Edited By Ron Laden on 14/11/2021 06:53:39
                #571203
                Chris Crew
                  @chriscrew66644
                  For gauge plate, key and silver steel try Coventry Grinders. They also supply all manner of grinding wheels too.
                  #571204
                  File Handle
                    @filehandle
                    I think that 10 by 10 might be harder to get because of its use in the Paul Sellers router design.
                    #571451
                    Howard Lewis
                      @howardlewis46836
                      Keith,
                      Not from a number some UK suppliers of HSS toolbits!
                      Make ,your choice, based on availability, service and price
                      #571490
                      Dave Halford
                        @davehalford22513
                        If you only intend to use it on the mild steels available, cheap-er HSS may do, if used on more exotic steels things will go bang. That said I have had taps that don't tap mild steel as well as centre drills that explode on exotic stuff from an ME show trade stand that Dormer etc are happy to cut.
