Posted by Emgee on 09/03/2021 09:21:17:
Dr
Only if the inserts are varying thickness, not because of the change of tip radius.
The tip radius changes the amount of movement needed to cut to the centre of the work, larger radius insert requires more travel.
Emgee
I know, but that's what I'm asking.
The tip radius changes the length, but that's not relevant for me because I'm doing manual work and measuring as I go.
However, the tip height is what I'm asking about – because that'll always affect facing or turning operations to a degree. setting tool height is trial and error for me, so if I knew that all inserts were made to a height standard, then I could swap them and not worry about re-checking and re-adjusting my tool holders.
